Windows 7: "Static sound" problem; out of ideas to solve/fix
06 Aug 2013   #11
fireberd
Although I have a recording studio, and am an ex guitar amp tech, its still baffling to me how it works. If you are connecting via HDMI then its a digital signal, but at the source, video game console, it would appear the signal if very low. If you could get that signal up to a higher level, it may be that will fix the problem.
On the other hand the interface card in the PC that is distributing the signals from the HDMI may be the culprit (is there any way of controlling or the audio level there?).
What the Xsplit, or whatever recording software, is "seeing" for volume level is low and thus the noise.
08 Aug 2013   #12
fireberd
Have you given up on me, or have you found the solution?
12 Aug 2013   #13
PhantoM47
Sorry, I had to go away for a few days and forgot to say. My apologies.
I don't think there's any kind of way to "boost" the signal at input level, as it were. What I now think is the most likely culprit is my capture card itself (in a PCI-Express slot). I updated the drivers for that and it seemed to actually make the "static" louder. In fact, I can actually hear it a little bit now when I simply turn up the volume to max on my headset's MixAmp master volume. With the capture software open (native to the capture card or with XSplit) it's even more audible than before I think.
So, I'm pretty confident that it is the culprit. The question now is what can I do to solve it? When I have the time (tonight after unpacking or tomorrow) I'm going to open up the PC, remove the card from my motherboard and see if that makes the issue clear once and for all. Will get back to you ASAP.
12 Aug 2013   #14
fireberd
Thanks for the update. Let me know how you make out.
14 Aug 2013   #15
PhantoM47
Okay, my capture card is out and the sound is the same. After speaking to a friend with the exact same set-up (same mixamp, headset, capture card, etc.) he reckons it's probably the motherboard, which is what I was thinking as well. My sound card is on-board, I was thinking that if I bought a separate one it may be the solution?
Edit:
Extra info just now. Was opening a video player on a web-site (flash based I presume) and when I flicked between full screen and just the normal boxed player, the sound intensified (when it went full screen) as it does when I open XSplit for example. So is there a chance this is a Flash driver issue? A conflict?
[Realtek][Win7] "Scratchy" Sound Problem
Hello Ive been browsing this forum to see if I could find any solution to my problem but I havent been able to track down any. So I decided to go ahead and ask you guys ;) First a little info about my specs: Motherboard: Gigabyte GA-EX58-UD3R Soundcard: Onboard Realtek OS: Windows 7
Static when recording as well as a new wireless headset "snow" problem
Hey guys, I made a thread a few years ago about me recording with a Plantronics 380 while using a dolby 5.1 usb soundcard to make the volume louder so people can actually hear me and getting a bit of static issues while recording as heard by the attachment I added with this post. Now recently...
Laptop speakers emit a "pop" sound after "Starting Windows"
For a couple weeks now, My laptop has been making a "pop" sound everytime on start up after the windows logo comes together it makes a faint pop sound then continues to the login screen. Everytime I muted or unmuted the speakers it would make the sound too. I changed my driver the the Windows...
I have "DHCP" how can I use "Static" IP on a wireless connection?
I don't know if this is the right place, but I seriously need some help. I've got an IP that changes every time my "gateway" (router) is reset. First of all, I'm using windows 7 ultimate 32 bit. AND IIS. (Internet information services) or something like that.. It's really annoying, because...
Network & Sharing
"Solve a problem with PSIKey"
I wasn't sure which forum to put this in, but I figure anywhere is better than nothing. In the last few days, I've had a new problem crop up. It may be two different things, but they seem to happen around the same time. One, about 90% of the time I have more than one window of Internet...
BSOD Help and Support
did i solve the "wake-up" pc problem?
just fyi i have a gigabyte p965-ds3 m/b and am running win7u. i used to have much frustrations in "waking up" my pc after hibernation despite not allowing it to sleep at all via change plan settings. i didn't fiddle with the m/b bios as i didn't have this problem when i was running vista. ...
Performance & Maintenance
