Windows 7: No audio device output installed, no sound, video game controller...
07 Aug 2013   #1
jehuty2013
windows 7 ultimate 64 bit sp1
Normally using my laptop last night. When i opened it this morning. I have no sound and the deadly X red mark on my volume on my lower right screen is present.
It is obvious that this problem (no audio output device installed) is very common to many. Reading through hundreds of threads saying i just have to find "sound, video game controller" and re install it. The problem with mine is that i dont even have that kind of tab on my device manager? how come?
(By the way...when i open my Device manager. I can see under Other devices that i have 3 Base System Device that has a yellow exclamation marks on it) FYI
I tried looking for sound programs in my computer (through search, through dxdiag, etc.) and i cant even find a sound driver. Because of this, i go to Realtek and installed the newest high definition audio codecs for 64bit windows 7 which version is R2.71 update 2013/4/8. Feeling confident that i can now install it to my device manager...i tried doing it. To no avail, i cant install it...this is the procedure that i am doing...
1. Device manager
2. Add legacy hardware
3. Next>choose Install the hardware that i manually select from a list. Next
4. Choose Sound, video and game controllers
5. choose Realtek. Next, Next
6. THEN...after installing...it will say...."An error occurred during the installation of the device. The extended attributes are inconsistent" FINISH
I really dont know what to do about this. If anyone can kindly help me, i would greatly appreciate it. I am not very good with computer terms so do bear with me.
Operating System
Windows 7 Ultimate 64-bit SP1
Intel Mobile Core 2 Duo T5250 @ 1.50GHz 53 C
Merom 65nm Technology
RAM
1.00GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)
TOSHIBA Satellite U305 (U2E1) 52 C
Graphics
Generic PnP Monitor (1280x800@60Hz)
Intel Mobile Intel 965 Express Chipset Family (Toshiba)
149GB TOSHIBA MK1637GSX ATA Device (SATA) 50 C
Optical Drives
HL-DT-ST DVDRAM GSA-U10N ATA Device
MagicISO Virtual DVD-ROM0000
Audio
No audio card detected
Manufacturer TOSHIBA
Model Satellite U305 (U2E1)
Version PSU30U-04R012
Chipset Vendor Intel
Chipset Model GM965
Chipset Revision C0
Southbridge Vendor Intel
Southbridge Model 82801HBM (ICH8-ME)
Southbridge Revision B1
System Temperature 51 C
BIOS
Brand TOSHIBA
Version V2.50
Date 8/30/2007
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Unknown
Bus Width 32 bit
Slot Designation PCI Slot J8B3
Slot Number 0
07 Aug 2013   #2
fireberd
The first approach, since it worked and then the next day didn't is to use the System Restore and restore the PC back to an available restore date that is Prior to having the problem. This fixes many problems, including your problem many times.
System Restore can be accessed from Start/Programs/Accessories/System Tools. System Restore will not delete any user data or e-mails.
BTW, please fill in the "My System Specs" rather than try to list them on a post (along with much of it not needed).
07 Aug 2013   #3
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by jehuty2013 View Post
1. Device manager
Operating System
RAM
Graphics
Optical Drives
Audio
Chipset Model GM965
Chipset Revision C0
BIOS
Brand TOSHIBA
Version V2.50
Date 8/30/2007
PCI Data
Slot PCI
Slot Type PCI
Slot Usage Unknown
Bus Width 32 bit
Slot Number 0
Hi jehuty2013,
You need drivers for the system to be updated. It doesn't make sense regarding why all of the sudden drivers would go missing on the system.
If it was working earlier you could try system restore:
System Restore
If the issue still persists, then right click the device with the yellow mark. Then select properties>details> select hardware id.
It should display information like "PCI_XXXX & VEN_XXX" so that we can find out the required drivers for you.
Also, kindly update your system specs here by following this.
Keep us posted with the results so we can advise you further.
07 Aug 2013   #4
jehuty2013
The story is...i was using my laptop normally yesterday evening. After opening it again today, the sound is now missing.
Yes..i already did a system restore...about 2 times already. The system restore was successful BUT i still dont have sound. Up until now i still have a red X on my volume and still doesnt have sound, game controller on my device manager. :'(
How about viruses? malware? although i dont remember being alarmed by my Malware bytes or my Avast about a virus...Ofcourse i am not 100% about it. What do you think? I will do full scan of both of them just to make sure.
I dont get it why even i have installed a new Realtek it doesnt recognize it or i cant put sound, video game controller on my Device manager?!
I have 3 Base System Devices under "Other devices" that has a yellow exclamation point. Doing what you said...here are the results...
1. PCI\VEN_1180&DEV_0843&SUBSYS_FF501179&REV_12
PCI\VEN_1180&DEV_0843&CC_088000
2. PCI\VEN_1180&DEV_0852&SUBSYS_FF501179&REV_12
PCI\VEN_1180&DEV_0852&CC_088000
3. PCI\VEN_1180&DEV_0592&SUBSYS_FF501179&REV_12
PCI\VEN_1180&DEV_0592&CC_088000
There you go...I really hope you can help me cause i really dont know much about computer stuff :'(
07 Aug 2013   #5
jehuty2013
By the way...I also have read the BIOS thingy....i dont have any idea what it is or how i may be able to go there(if it is a place or what, hahaha!) There are so many ideas on the net but it doesnt seem to work. As far as now, these are the things i did that failed/did not do anything:
1. System restore
2. Download Realtek and install
3. Add legacy hardware
How do i check if my sound card is still up and running and not damage? I am afraid and dread that it might already be broken(hoping not! dont have extra money to repair or even buy new one ). This laptop is bought since 2007 i think(pretty obvious from its specs)
07 Aug 2013   #6
fireberd
That model is not listed by Toshiba. There are U305's, but not the U2E1 designation.
However, reinstall the Intel motherboard chipset drivers and then the Toshiba supplied sound driver.
07 Aug 2013   #7
jehuty2013
@fireberd - I dont have any idea about it...i just copied what appears written there. When i flip my laptop, it says Satellite u305-s7446
How do i do this? my computer literacy is at a minimum. If u can kindly tell me the steps how to do it, i would greatly appreciate it!
Thanks!
08 Aug 2013   #8
fireberd
The "s7446" is the correct designation and not "u2e1"
Chipset drivers Satellite U305-S7446 Support | Toshiba
Sound driver Satellite U305-S7446 Support | Toshiba
From the description on the Toshiba site, these are Zipped files and must be unzipped and then installed. Install the chipset drivers first. The files are self extracting and running. They will extract to a folder then run the installation.
08 Aug 2013   #9
SandeepP
Winndows 7 32 bit
Hi jehuty2013,
Thanks for providing us this information. I have searched for all the devices you have mentioned and it seem all indicates to the Ricoh card reader driver is missing on the system.
Please check these link below from where you can try and install the drivers:
Dell Studio 1535 missing driver in Windows 7 x64 (Base System Device) - TechSpot Forums
Base System Device
Implitech Ricoh PCI\VEN_1180&DEV_0852
Also, regarding the audio drivers please let us know the correct model number of the system so we can locate the audio driver for you :
Drivers & Software Support | Toshiba
08 Aug 2013   #10
jehuty2013
Hi Sandeep! thanks for the reply...about the sound(which is the one i want to repair). Up until now i dont have it and the red X mark is still there. Regarding the website Toshiba Drivers...i write my model number on it and the next screen has "Filter by" on the left side. I click "Sound" and on the right side appears several options. I dont have any idea what to choose there?!?!
Copy pasted it:
1.Toshiba Speech System
Posted Date: 2009-11-10 | Version: 1.00.2520 | Size: 21.35M
2.Realtek Audio Driver for Windows 7 (32/64)
Posted Date: 2009-09-04 | Version: 6.0.1.5854 | Size: 36.27M
3.Toshiba Speech System for Windows 7 (32/64)
Posted Date: 2009-09-03 | Version: 1.00.2519 | Size: 21.35M
4.Conexant Audio Driver for Windows 7 (32/64)
Posted Date: 2009-06-25 | Version: 4.8.0.0 | Size: 3.16M
5.Realtek Audio Driver for Windows Vista
Posted Date: 2007-12-12 | Version: 6.0.1.5473 | Size: 18.88M
6.Realtek Audio Driver for Windows Vista
Posted Date: 2007-06-06 | Version: 6.0.1.5420 Logo | Size: 18.3M
7.Toshiba Speech System for Windows Vista
Posted Date: 2006-12-20 | Version: 100.2512 r2 | Size: 19.76M
My apologies for taking so much time from you guys. I really am not very good with computers :'(
No Audio Output Device Installed/No sound card found
Hello all, I hope you could help me with my problem. Recently, I got problem with my PC, just all of a sudden, it stopped booting and later on the HDD got wiped and I have no saved data. So I reinstalled using USB, before I was running Windows XP, but I prefer to install Windows 7. The thing...
No sound, video game controller in device manager. No audio full stop.
I was rudely interrupted during a truly hilarious episode of Curb Your Enthusiasm to the cruel sound... of silence. I know this is an old problem, I've searched high and low for a fix for hours, but none seem to pertain to my specific set of circumstances. Any help would be great. Situation...
Missing Sound Video & Game Controller in Device Manager, no sound
Hi Its bit complicated.:D I have 5 year old Compaq Pressario V3611AU notebook with AMD Atholon X2 TK-55 processor. Was using Windows XP and everything working fine. Recently I upgraded RAM to 2GB & processor was changed to AMD Turion(tm) X2 TL-60 2.00Ghz. I installed windows 7 and everything...
No output device/ no sound video game controller
Please help!!!! I have that horrible problem of" No audio output device installed" and the red x over my sound icon, which means no sound. BUT I also have another problem. Many say to fix this problem with windows 7 by going to device manager and fixing it under the catagory of sound video and...
'no output audio device is installed' but sound plays
As above. It says this in the icon in the tray, yet i can play songs fine. The only thing is, it also has my speakers to record, and i can't change it to front mic. any ideas? it was working perfectly fine yesterday... sound is onboard and uses Via hd audiodeck. thanks
No Audio Output device is installed! no sound! :(
Hello everyone, i have seen this posted before but my problem is a little different. I can not even find what my sound card is or where it is. I have looked and looked and there is nothing on my computer to show it has a sound card. It did indeed work before i upgraded to 7 so it has to be there....
