Windows 7: Creative SB Audigy SE sound problem
07 Aug 2013   #1
dmy
windows 7 ultimate 32bit
Hi, I had a problem with my old sound card. It was not working at all. So i bought a new one Creative SB Audigy SE installed the drivers and everything that was given with the sound card and the sound is really weak. I have all the volume up to 100% everywhere and it''s playing music like it is 50% or less. When I put my headphones on my phone the sound is louder 2 times or more. What could be the problem?
07 Aug 2013   #2
fireberd
Windows 7/10 64 bit
What was the old sound? Built in (on the motherboard)? or a separate sound card? If it was the built in sound, disable it in the BIOS so it does not potentially interfere.
Also did you move the front panel headphone/mic jacks to the new Audigy SE sound card? If not, you are hearing the old PC's sound card sound in the hadphones.
07 Aug 2013   #3
dmy
I think it was built in on the motherboard.
I plug in my headphones directly to the new sound card from the back of the computer.
I just disable the built-in sound card it is called "azalia codec". The sound is the same.
07 Aug 2013   #4
fireberd
Windows 7/10 64 bit
Did you disable it in the BIOS or the Device Manager? Best to do it in the BIOS.
Since you are plugging into the rear jack and its apparently loud with the headset, there must be a problem with the speakers?
Plug the speakers back into the GREEN speaker jack. Then go to the Control Panel/Hardware and Sound and finally the Sound Panel. Your "Speakers" (the Audigy) should be set as the default playback device. Click on the Icon for the speakers to highlight it and then click the Configure button. Make sure you have the correct speaker type set and then you can test the speakers in the Configuration panel. See how that works out.
If its still low, power off the PC, open the case and reseat the SoundBlaster card (unplug then plug back in, making sure its fully and correctly seated). Then try again.
08 Aug 2013   #5
dmy
Yes i disable it from the BIOS.
You didin''t understand. When my headphones are plugged in the computer the sound is weak and when i plug the same headphones to my telephone the sound is like 2 or 3 times better.
I don''t have any speakers only headphones. But I did the thing you told me in the sound panel. Nothing helped.
The card is seated properly, I checked it 2 times.
08 Aug 2013   #6
fireberd
Windows 7/10 64 bit
What headphones do you have? If you have iPhone headphones, some of these do not work or work properly on a PC.
Here is the connection diagram of the SE. Make sure you are connecting to the GREEN (#2) jack.
08 Aug 2013   #7
dmy
Im using acme headphones. They were playing loud with my old sound card until it stopped working.
Yes my headhpones are connected to the green jack.
Could it just be that this is a lame sound card and it is giving maximum sound?
08 Aug 2013   #8
fireberd
Windows 7/10 64 bit
Sadly it does sound like a defective card. Can you return it for replacement, either where you bought it or under warranty with Creative. I used an Audigy SE for a long time on an old Dell, first with XP and then with Vista 32 bit.
09 Aug 2013   #9
dmy
Ill try to return it. Thanks for your help.
09 Aug 2013   #10
fireberd
Windows 7/10 64 bit
It may not be the problem, but its the prime suspect.
Creative audigy 4 crackling recorded sound HELP :((
Hi, I have problem with my creative audigy4 sound card, i use FL studio 9 and pianissimo piano software, or any other it does not mether, and midi evolution keyboard, and when i try to record my self, playing live, with microphone on and these plugins, the recorded sound is cracling, like...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Audigy 2 sound issues
While playing a game, listening to music, talking on ventrilo my audio starts getting distorted. The best description I can think of is it sounds like a metallic freaky sound. It last for a minute or so and then it starts to clear up and returns to normal. This happens a couple times per day and...
Creative Audigy LS no sound through S/PDIF
Heey, Recentley I bought the logitech Z-5500, along with a lot of cables. I want to hook up 2 speaker sets to my Audigy LS, my standard speakers and the Z-5500. I connected the standard speakers with the 3 normal 3.5mm jacks. However now I want to connect my Z-5500 to my souncard using the...
Creative Sound Blaster Audigy LS Not Working
Hello, I've installed Windows 7 on my desktop with dual boot to Vista. Everything's been working fine but I haven't been able to properly setup my sound-card to function properly. As of now, I currently have no sound and I've been through many different drivers from the Creative website. I've...
