Windows 7: Realtek HD Audio RCA Recieve No surround
12 Aug 2013   #1
Trenidor
win 7 64bit
Hey all,
I got a new (old/used) RCA Receiver (RV-9953A) and 5 monitors and a subwoofer. When I put in a cd or run the test tone on the receiver all of the speakers and subwoofer check out--no problems.
When I run a test on the Realtek HD Audio Manager however, it doesn't want to play from the back speakers and it acts like it's in stereo mode (but the subwoofer works).
Is there something I'm missing about how to set up windows/realtek to play my audio in 5.1 format?
Thanks!
12 Aug 2013   #2
Trenidor
win 7 64bit
Ok, turns out what is happening is my onboard Realtek sound card is only exporting either the front or the back--but I have the sound input (and this is the only way to do it) as a left and right RCA cable (goes from 1/8" to RCA) Is there a way to mix the two lines on my computer before they output?
13 Aug 2013   #3
fireberd
What is the link to the RCA? Digital or Analog? Where are you getting the 5.1, playing something on the RCA?
A little more info, please.
13 Aug 2013   #4
Trenidor
win 7 64bit
Ok, I've been looking into this.
I have the realtek ALC662 onboard. It has 3 (2.1) output/input jacks. My receiver only has left and right stereo RCA cable inputs. (I have a 1/8" to RCA cable)
What I believe is happening is when I set my realtek to surround, it transmits the signal through 2 of the 3 (2.1) ports. (rearL+R and frontL+R) But my receiver is set up to do Dolby Pro Logic, and only connected through the frontL+R port.
So I suppose the next step is: how do I set my realtek sound card to export an encoded front and the rear signal through only one of the ports so that it can be decoded by the receiver? OR is there more to this than I am thinking?
13 Aug 2013   #5
fireberd
If you are just running analog audio from the speaker out jack, you will only get two channel stereo. You would have to hook up the three speaker outs to equivalent inputs on the receiver to get surround sound.
The other option, if there is a digital S/PDIF output on the PC and you have an S/PDIF input on the receiver you MAY get surround sound. Some PC digital outputs are just two channel stereo and some are multi channel surround sound. I can't say what yours is.
13 Aug 2013   #6
Trenidor
win 7 64bit
Ok, maybe that's how it does it... through s/pdif --So is there any way I could take 2 analog stereo outs and convert them to S/PDIF multichannel?
13 Aug 2013   #7
fireberd
The S/PDIF would have to be generated in the PC and a separate S/PDIF output. Combining the Analog 2 channel stereo to digital will not generate a surround sound signal.
According to the spec's for the motherboard, there is an S/PDIF header (port) on the motherboard. If the receiver has an S/PDIF input, you could connect to the motherboard header with the proper connector and use that.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek onboard sound card with 5.1 surround speaker fill problem
I recently installed a new motherboard Asus Sabertooth 990FX. It has an on-board sound card "Realtek® ALC 892 8-Channel High Definition Audio CODEC". I'm using 5.1 surround speakers from creative. Speaker fill with windows update driver, or Realteks driver from Asus' website, has the same outcome. ...
Windows 7 5.1 surround problems (realtek)
In my Windows 7 beta I cannot get the 5.1 surround sound to work properly. I have an integrated realtek hd chip (which works perfectly fine in Vista). The 5.1 sound works well when testing the sound in the windows sound settings but whenever I try some other playback (wmp or whatever) only the...
5.1 Surround Problems with Realtek HD Audio Manager
Hi everyone! First post on the forums =P What the title says. Basically I have had to remove my soundcard (a Creative X-Fi Soundblaster) as it was completely blocking off the fan on my new graphics card (ATI Radeon HD 5850 - and yes there is no space left on my motherboard!). As a result I have...
Surround Sound + Realtek
OK So! Ive tried EVERYTHING even bought a new set of speakers thought the others were broken. I am running windows 7 ultimate and i have tried every realtek driver known to man. And I still can't get my surround sound to work I haven't re-assigned the jacks cause i am not to sure how to do that...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
