Windows 7: Loud sound thump on power up and down
14 Aug 2013   #1
ICIT2LOL
I have just got my Ivy Bridge up and running again but am faced with another small problem and that is I get the loudest thump / whack through the sound system on power up and down.
Now it doesn't matter whether I have the sound turned down to zero the sound is still there especially on power down. I havn't tried unplugging the sound system but am assuming it is only coming through it anyway.
Sound is through an Asus Xonar DG card and I am not wanting this thumping to go on much longer in case it produces surges that might damage the rest of the board set ups.
14 Aug 2013   #2
paulpicks21
Windows 7 Professional 64 bit
You are not having much luck lately are you John
How about trying with the speakers/sound system connected to the onboard sound instead of the Xonar. If the problem goes away then you know it's some kind of issue with the Xonar.
Paul.
14 Aug 2013   #3
ICIT2LOL
Quote   Quote: Originally Posted by paulpicks21 View Post
Paul.
Ok Paul I whip out the Xonar and try that maybe the Xonar has eaten the biscuit and I will have to replace it.
18 Aug 2013   #4
ICIT2LOL
Well have found a solution if it is a solution that is to have the Logitec turned down to 25% or less and use the volume control on the Xonar / keyboard at least it is not trying to turn the speakers inside out.
Sound Goes Loud and Quiet Continuously!
Hi, This started happening a few weeks ago. I actually thought it was my old speakers that were faulty, so I replaced them with decent speakers, and as most of my work is tutorial videos (with speaking), I didn't notice it happening on my new speakers too, but then I played music and it was...
Sound unmanageably loud
Yesterday I upgraded from Windows XP SP3 to Windows 7 and while the transition was mostly smooth, I'm beginning to regret the change as a result of the seemingly (and unnecessarily) simplified volume controls on Windows 7. I'm using a Creative X-Fi Fatality Professional series sound card (yes,...
my sound will not record loud enough
i want to read and record stories for my grandchildren to put on cd for Christmas. WHen I use the wondows 7 sound recorder, I sound so far away. I have tried to use a gaming headset with a microphone also but still, it's barely audible.. Any suggestions how I can make this recording clear, and...
My Sound is too loud how do i tone it down a bit?
I dont know if this should consider to be a problem but its a little annoyance to me, the sound is too loud even if i turn it down or turn down the application sound (Example: Youtube) is there anyway for me to tone it down a little bit?
Sound Very Loud With Headphones On Windows 7 RC
I have volume set around 8% and for some reason it is way louder than on Vista. On Vista I usually have it around 22% when I use headphones. On Windows 7 RC it's extreme loud when I set it to 22%. Anyway to fix this? I tried everything in the sound properties.
Sound Blaster Audigy 2 isn't nearly as loud in Win 7
my sound card is the SB audigy 2. Back in XP the drivers usually worked fine and produced the right 'loudness' of sound. however in windows 7 the drivers that were automatically installed upon the OS installation do NOT play audio at the regular decibel levels. I tried going to downloading the...
