Front Panel on both builds not working
  1. Posts : 21
    Windows 7 Professional 64bit
    The Bios has already set up HD on Audio
    I put in the Front Panel on the right slot
    Also the Cd with the drivers are installed
    Help please? Thanks!
    Only the Front Panel Audio Is not working
    Motherboard is Z87-A
    Antec Case http://www.memoryexpress.com/Products/MX37559
    NZXT Phantom 410 http://www.memoryexpress.com/Products/MX39159
    Most cases come with audio connectors for HD Audio and AC97. The HD Audio connector should be used, but since you are having problems, use the AC97 and see if makes any difference.
    As you have two cases doing the same thing, is this with the same motherboard or different motherboards?
  3. Posts : 21,004
    Yeyo as firebird says are they two different boards? In any case check the manual for both and make sure you are using the right headers for the audio. They are usually situated along the edge away from the CPU side of the board.
    Attached Thumbnails Attached Thumbnails Front Panel on both builds not working-board.png
  4. Posts : 21
    Same Motherboards
  5. Posts : 21,004
    Try downloading the drivers again Yeyo P8Z77-V LK - Motherboards - ASUS I find it better to update them from the manufacturers rather than the Windows service.
  6. Posts : 21
    I tried it, my front pane ports are still not working it was working b4 on another motherboard but got fried
  7. Posts : 21,004
    Yes mate I know this is tedious but just check again the cables are in the right header now I don't know but just maybe the contacts on the front panel plugs have got damaged from the previous motherboard frying.
