Windows 7: surround sound issue
24 Aug 2013   #1
gowonsouth
windows 7
Recently, windows did an update. Since then, I lost my surround sound, (realtek drivers). Every time I try to change the settings to enable it again, I lose all sound and have to uninstall then reinstall realtek. If I don't touch the settings, I get sound through the monitor, but once I try and change them, windows trouble shooter says my peripherals are not plugged in. I have not unplugged nor changed any hardware or wiring configurations. I have looked for a solution. but can't find any posts related to this. Not sure if there is some setting I am missing that I should change. Any help will be greatly appreciated.
24 Aug 2013   #2
linnemeyerhere
Windows 7 Ultimate 64
Welcome gowonsouth to SF.
Right click on the speaker icon in the lower right hand of the screen. Then select playback devices and set your realtek as default device.
24 Aug 2013   #3
gowonsouth
windows 7
Ok, that opens the options to choose between ATI HDMI output (works), realtek digital output (sound bars move but no sound), and realtek HDMI output (sound bars move but no sound). At least I didn't have to uninstall and reinstall, but still not getting any sound through my surround sound speakers. Could this be a problem with the output jacks on my monitor possibly? (as in they are not working at all now for some reason?). and thanks for the reply by the way
24 Aug 2013   #4
linnemeyerhere
At the Realtek device wanted open up properties and see if you can configure for 5.1 and other tweeks. Also understand that very few programs have strong rear channel info so they don't sing like the front mains will.
24 Aug 2013   #5
gowonsouth
windows 7
The realtek HDMI has the option for 5.1, but no sound at all, even during the test. Not sure why. It was working fine before the update.
24 Aug 2013   #6
linnemeyerhere
You can always restore back to the date and time when all was well if your rig was set up to save restore points, maybe the best and quickest fix.
24 Aug 2013   #7
gowonsouth
windows 7
Looked at the option for restore points, but all were lost with the last update. However, thanks for your help, but went through the hassle of hooking up and using an alternate monitor, seems the issue is with the output jacks on the new monitor. It is going back to the store. Thanks for your help.
24 Aug 2013   #8
linnemeyerhere
Good to hear you are on track to sorting it out.
Need Surround Sound
Hi all looking in vain for Surround Sound System, that isn't a dvd/Blu-ray player or a AV Amp System, just need it to work for sound 5.1 or higher with a sub out, optical in, is there such a thing ??? cheers web
how to get 5.1 surround sound through TV's USB
hi......i recently brought sony32EX650 LED TV with Sony DVD player with home theater.and i want to watch HD movies on this TV with surround sound but we know dvd player don't play the Hd quality videos.But on TV's usb we can play those Hd videos and they have 5.1 surround sound also.and i can't get...
CPU to TV/Surround Sound Receiver Issue
After spending an hour or so trying to read through the 1,000's of HDMI sound issues, I decided to just register and post my problem because every "solution" I found is something i've already tried. I have a HDMI cable going from my Desktop tower to my receiver, with HDMI output already as my...
Another 5.1 Surround sound issue for Win7
I'm decent with computers, but don't know much about sound cards, so I'll be using some screen caps. I just bought some new speakers, the Logitech Z506s (front left/right, center, rear left/right, subwoofer). They are connected to laptop via a single cable, jacked into my single audio out. ...
Sigmatel IDT 5.1 Surround Sound Issue
I finally tracked down why my surround sound wasn't working. I went into the IDT control panel (not Windows 7 Sound and Hardware) and saw that the options for speakers were switched to Stereo Speakers, so I changed them to 5.1, but it instantly changed back to Stereo. Now everytime I try to switch...
5.1 surround sound help
I've recently found out that my sound card application (creative audigy) is not compatable with win7 and have yet to find any creative programs that work with my computer. Is there a way around this to still be able to play music on 5.1 surround sound? Like a generic application to play music in...
