Windows 7: Volume HUD Not Appearing When I Adjust Volume
25 Aug 2013   #1
ThePanduuh
I've seen plenty of these threads but none of them are eMachines computers. I have an eMachines E525-2200 running Windows 7 Home Premium 64bit Service Pack 1.
The volume hotkey is Fn + arrrow up / arrow down. I press these and I see in the corner that the volume changes, but not the HUD like I'm talking about. I've already updated the driver to the latest version. All suggestions are helpful!
26 Aug 2013   #2
maxie
windows 7 home 64bit
Hi there ... In order to get your Function Keys working you need Launch Manager software installed .. I think the Version you need is 3.0 .00 The problem of course is getting it working with Windows 7 as it was only meant for xp
26 Aug 2013   #3
ThePanduuh
Nope, launch manager is not even on my computer.
The volume adjusts, it just does it in the smallest increments it can because the HUD is not popping up. I just moved over to 3rvx and I have little problems.
26 Aug 2013   #4
maxie
So do the rest of your Function keys work ?
26 Aug 2013   #5
ThePanduuh
Yep. Like I said, they work, the little pop up window that shows me how high the volume (also called the HUD) and it is causing my volume to go up by ones when I hit the keys. It's very annoying. 3rvx is the only REAL replacement for it. I tried reinstalling the drivers as well.
26 Aug 2013   #6
maxie
I actually have that feature on my Laptop too .. But it does not really bother me
27 Aug 2013   #7
ThePanduuh
Thanks!
So I investigated a bit more, and saw that LaunchManager was installed on my computer. So I went to the driver site and downloaded the latest LaunchManager Application Setup files. I uninstalled it, rebooted, reinstalled it, rebooted, and it works! Thanks maxie!
27 Aug 2013   #8
maxie
Most welcome glad you got it sorted
Windows Audio Service doesn't start until I adjust volume
This problem has started in recent weeks (yes, too far back to do System Restore): When I reboot, if I click on the speaker icon in the Notification Area, it tells me that Windows Audio is not running (and so no media app will produce any sound). However, if I then raise or lower the volume via...
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can't read
Encrypted Volume Check: Volume Info on \\?\Volume{X}Can Not Read Found this in my Event Viewer on each start/restart. I don't have any Volumes that I have encrypted. Is this malware? I've run everything prior to noticing including Windows Offline Defender. Not sure if this is even the...
General Discussion
How to adjust volume from Standard PS2 wired keyboard
Can not access sndvol.exe to create a shortcut to allow keyboard to control volume. I am using a Standard PS2 wired keyboard for my HP Elite 8000 system. Details in my signature. I discovered the following and wish to implement with my basic keyboard: 1) click your start menu. Type...
BSOD! Cant Adjust Brightness/Volume or Connect To Internet!
I was on some random website when I got the BSOD error code and automatic restart. I ran all my malware, spyware programs and got rid of everything. So, I restart my computer, and now I can't adjust the brightness. The place where you could do that is just not there. It doesn't let you. Not only...
BSOD Help and Support
Programs minimize when I adjust Volume
Well the title pretty much says it all. Every time I have a program open and I use the keyboard to adjust the volume the program that I am using minimizes. I searched these forums for an answer but couldn't really find anything. Does anyone else have this problem? I am not sure what to do and...
General Discussion
2x Volume Mixer Appearing
Greetings people, I recently bought myself a Steelsound 5hv.2 headset coming with a USB soundcard. I also have a set of logitech speakers connected to my computer, but everytime I connect the headset through my USB this shows up. http://img443.imageshack.us/img443/9369/captureqs.th.jpg One...
