Windows 7: How to get System Tray Sound icon to show mixer
29 Aug 2013   #1
Dylan Morroll
N/A
When I click on the system tray icon for the sound, it always comes up with the overall speaker level and then you have to click the mixer button to get that to show up, I was wondering if there was a way so that when I clicked the system tray icon, it instantly showed the mixer for all the different programs.
Thanks for any help in advance.
29 Aug 2013   #2
Brink
Microsoft MVP
64-bit Windows 10 Pro
Hello Dylan, and welcome to Seven Forums.
If you like, you could use the Volume Mixer shortcut from the tutorial below to make it easier to open directly. You could pin the shortcut to the taskbar, or use where you like.
Volume Mixer Shortcut - Create
wlan icon and sound icon on system tray not working
Good morning experts, Please help me since I dont know what to do to solve this. This mornig I started my laptop, after a few minutes the wifi disconnected and the yellow dot showed on the wifi icon. I tried to click on the icon but nothing happened. Tried to click click clik and nothing...
Network & Sharing
Stuttering sound + Sound mixer "System Settings" flashing in and out
This is a weird issue I'm having. I did a restart and when I came back BF3 wasnt playing any sounds, which is weird because it was just working. I went to make sure it wasnt muted in the mixer, and I see the weirdest thing. The application "System Sound" is disapearing in and out very...
Unknown icon in system tray - slow system - pic attached
Hi, I've been having some very slow system issues today and have checked that system resources seem to be at normal levels - CPU usage at around 20% and Memory usage at around 50% during normal operating. However I have noticed a new icon in my system tray which I can't identify, can't click...
Performance & Maintenance
Sound/Mixer icon has red cross. No Audio Output Device is installed.
Windows 7 32-bit won't play sound. Device Manager\Sound, video and game controllers\High Definition Audio Device ok. Double click and window says: High Definition Audio Device Properties\General: Device status says This device is working properly. Speakers are plugged in and make a crackle...
How to show Win7 firewall icon in tray?
I've been using Comodo for years, all throughout my XP years until I switched to Win7 a couple months ago, but have been getting frustrated with its frequent 100% cpu usage with Windows 7. I'm now working on switching over to the built-in Win7 firewall instead since I think it'll meet my needs just...
Network & Sharing
