Windows 7: Realtek HD Audio Manager ''Mute Rear Speakers'' HELP
30 Aug 2013   #1
icoloram
Windows 7 64 bit
Hey,
For quite a while now i've been using a pair of USB Speakers.
I had it set so my games came out my speakers and my Team speak Voice chat came through my headset.
I recently decided to swap back to my Creative speakers, but now i have an issue.
When i plug my speakers and headphones in the Realtek HD Audio Manager is only detecting one device. (Muting my speakers when my headphones are plugged in) I've managed to get them both working at the same time but due to the fact it's only detecting one of them i can't organize / change which programs use which.
I remember at one point in the past when using these that i selected ''Mute rear speakers when front pannel is in use'' but now i can't seem to find this option?
I've looked at a few forums that say ''Go into Device advanced settings'' and even seen a screen shot of someone pointing out that it's at the top right on the Realtek HD Audio Manager, but on mine that option is not there and nor can i find it!
Any and all help would be lovely! Thanks <3
Attached is a screen shot of what my Realtek HD Audio Manager looks like with BOTH Headphones and Speakers connected.
30 Aug 2013   #2
fireberd
My RealTek HD manager has a "Device Advanced Settings" option which allows how the headphone/speakers act. Yours does not appear to have this option. Some Vendors include this and others do not, and using the generic RealTek sound drivers instead of the PC Vendor (or motherboard on a custom built system) drivers does not always work or work correctly.
Using USB audio devices is a separate function and the reason it worked with the USB device.
My RealTek Manager:
30 Aug 2013   #3
icoloram
Windows 7 64 bit
Sooo is there anyway for me to sort it?
I've updated and re-installed my drivers etc, still got the problem.
They use to work individually on this computer and i have seen the advanced settings before, as i set it to mute the speakers when the headset was plugged in
30 Aug 2013   #4
fireberd
I don't think you can without the "Advanced Settings" options.
You haven't filled in much of the My System Specs so we don't know exactly what your system is.
If you are using the drivers from the RealTek site, reinstall your PC vendor's drivers. If you are using the PC Vendor's drivers, try the RealTek drivers.
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
Realtek Audio HD Manager does not auto-detect speakers
Hi all, I recently updated my AMD drivers as Civ: Beyond Earth asked me to. Since then, the Audio Manager has not been able to detect the speakers automatically. I regularly plug in and unplug my headset and previously the system would detect it being removed and automatically switch the...
Realtek HD Audio/Creative Xtreme Soundcard No rear speakers.
To start, Hi, I am a first time poster to sevenforums, and registered here because of the wealth of information threaded out over the years. Well done to all. Right now down to the serious :). I, as many others have experienced the sadness of upgrading to Windows 7, only to find that my 5.1 rear...
Realtek Mute Rear output when front input is plugged in
This doesn't work. Very irritating. (I don't know if this RealTek sticky at the top of this forum is a solve for this, I'm not hot on registry changes and I'm not sure if this is a fix for this issue.) Firstly I have to turn off the front-panel detection in order for the front panel to be...
Realtek HD Audio Non Working Rear Speakers
Hello Everyone , I recently searching in forums to get solved my problem , but no one fix that issue . I Read many threads so i need the fix because i'm sick to see another posts from fools that they don't know anything about software's or hardware's. So My Problem Is : Yesterday i format...
Front headphone jack does not mute rear speakers
Asus M4A78-EM motherboard using Realtek drivers from Asus site. The front headphone jack did not work until I installed the Realtek drivers from the Asus site. Actually they didnt work until I checked on Disable Front Panel Detection. That got it going but the rear speakers are still...
