Windows 7: Bass boost breaks sound and causes it to be robotic
30 Aug 2013   #1
Menthax
Hello,
I am new to this forum due to a bug with my bass boost. I had some problems earlier with my gigabyte GA-990FXA-UD3, Socket-AM3+ and my Tiamat subwoofer not working. Uninstalled Realtek and Dolby to get it working again. Now i have some bass atleast,eventhough i would like to have some more. So i tried to enable bass boost as it worked great in my past.
So here is the problem: If i enable bass boost, after some time, the sounds start going all robotic (noticed it first on skype) and as soon as I disabled bass boost again, everything worked great.
Ask me if you wonder about anything, ill try my best to explain.
Thanks in advance
30 Aug 2013   #2
fireberd
When the bass goes bad, is it just in the speakers? Does it also sound bad in a headset?
30 Aug 2013   #3
Menthax
Only my Razer Tiamat 7.1 has the problem yes, however it is weird that it is like this as Razer themselves say this is what is needed to be done (Tiamat is headset, not speakers, however i am currently trying with speakers and it seems to go fine)
Edit: It usually goes bad after 10-30 minutes, so far speakers have stayed on for ran hour without problems. Seems like it only is the tiamat
30 Aug 2013   #4
Menthax
My pc also seems to start lagging alot when the problem occurs (programs and music start running at X0.7 speed). Still only happens to headset. I have never heard of this problem and could not find anything about it. Sort of hoping you guys know anything
31 Aug 2013   #5
fireberd
With it "lagging", one thing I see is you have the (dreaded) Kingston Value RAM. That is one of the least desired or recommended memory. The regular Kingston is OK, but I've seen the Value RAM with compatibility problems and even to the point of not working in some. Other tech's that I know have the same opinion on the KVR. It may not be the problem, but one area to be considered.
31 Aug 2013   #6
Menthax
so what do you reccomend for me to do? Ive got a spare Kingston DDR3 HyperX 1600MHz 8GB too, is it any better to switch em ?
31 Aug 2013   #7
fireberd
I don't know if that is the real problem, but its worth a try to see what happens. Eliminate any potential problems.
How can I get more control over bass boost?
Hello, I know how to turn on bass boost through the enhancements section if the control panel, but I find that that is usually too much. How can I lower or tweak the bass boost? Is there another program that can do this?
Sound goes high when no bass > Realtek
Heya heres my problem, Iv had this for a few months I am REALLY but really sick of it, i have no idea how to fix it. Im using onboard sound realtek HD, latest driver installed. My problem is that sometimes my sound goes really high when there isnt any bass playing. When high bass, the sound...
Dell XPS L702X Audio Driver Bass Boost Problem
Bass Boost Configuration not present in the properties of my Speaker/Sound Settings. Using the Category View in the Control Panel, I left click Hardware and Sound, and then Sound. I then right click on Speakers and select Properties. Following that, I go to the Enhancements tab, for my...
Drivers
Sound breaks/distorts without reason.
I've been having this problem for a few weeks and I cant find any help on this. I'm using Foobar v1.1.11 and I am experiencing a random breaks in music playback, for a fraction of second like when you plug in a earphone jack. I have the latest updated drivers from Realtek(check sys specs)....
Creative Sound Blaster Live 5.1 - Bass, Treble Balance
Hello, I have Creative Sound Blaster Live 5.1 running with EMU10K1 driver on Windows 7 7260 x86 build. Sound is OK, but there is a problem with Bass and Trebele Control - this control is freeze on minimum and doesn't work. Please, anybody have idea? Thank you very much. ...
What Does Changing dB do in Bass Boost?
I notice when I change the dB to higher the volume gets lowered. Is it safe to have dB at 12dB?
