Windows 7: conexant high definition audio and intel(R) High Definition Audio HDMI
01 Sep 2013   #1
FateIsFallen
i have a gateway computer and i want to record some audio from my computer. i looked online how to do this and stereo mixer kept coming up. i looked in my sound and show disabled and disconnected devices are both selected and i do not see stereo mixer in the list of recording devices. can someone please help me on how to get it?
02 Sep 2013   #2
fireberd
The Conexant HD Audio would be the device that supplies the Stereo Mixer, if Gateway enabled it. Some vendors have not enabled it to avoid DRM (Digital Rights Management) issues. I've seen a couple of Dell's that way.
Have you tried reinstalling the Gateway supplied driver? If not, give that a try first.
Gateway Support - Downloads & Support Documents - Notebook / NV Series / NV54
If that does not work, unless you can find a compatible Conexant driver somewhere else you may be doomed.
Microsoft High Definition Driver vs Realtek high definition audio driv
Microsoft High Definition Driver vs Realtek high definition audio driver?
Drivers
Realtek High Definition Audio and Intel Display Audio
I think my question is this: how do I set up VSX-1124 (a Pioneer AVR) in Control Panel/Sound and Hardware/Sound so that its driver is Realtek HD Audio and not the Intel Display Audio one? In Device Manager under Sound, Video and game controllers, I have two sound card drivers, Realtek High...
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
Conexant High Definition Audio
Hi, my laptop is NEC Versa M350 on Win 7, but I have no sound. :huh: PCI\VEN_8086&DEV_266E&SUBSYS_C00B1631&REV_04 PCI\VEN_8086&DEV_266E&SUBSYS_C00B1631 PCI\VEN_8086&DEV_266E&CC_040100 PCI\VEN_8086&DEV_266E&CC_0401 Any ideas to solve this problem?
Conexant High Definition Audio Windows 7 RC 1 No Sound
I have reinstalled Windows 7 twice and there is still no sound coming out of my speakers. I went to the HP Site and downloaded the latest (Windows Vista) Conexant High Definition Audio Drivers for my laptop model. Even with the drivers loaded, there is still no sound on my laptop. There is sound...
HP Pavilion dv8220ca / Conexant High Definition Audio
I have a (3 yr.) HP Pavilion dv8220ca Laptop. Looking for a driver that will be compatible with Windows 7. My friend bought the new OS for his exact same lappy (without too much concern about updating) and said that he cannot found a sound driver that will work. I want to upgrade to Windows 7 and...
Drivers
