Windows 7: Audio driver for Intel 945PVS Mobo running Win7 32bit
08 Sep 2013   #1
lumberjack83
windows 7 32 bit
When I have downloaded several drivers from Intel the High Definition Driver S/PDIF is the only one that installs. I've tried removing it from device manager, downloaded and installed the driver that Intel says will work, but no luck getting audio to the green 1/8th inch jack of the onboard audio. I can certainly pick up a pci audio board, quality is not important. I've tried win xp compatibility mode also with no luck. Any tips will be greatly appreciated. Thanks, Eric
09 Sep 2013   #2
ICIT2LOL
Hello and welcome Eric mate your latter suggestion would be my choice to be honest.
I run Asus Xonar DG cards in all my machines and cannot fault them. Great GUI - mixer / effects features and not expensive either.
Xonar DG - Sound Cards and Digital-to-Analog Converters - ASUS
Intel IDT Audio Driver will not install
I am trying to install the latest audio driver for the Intel® Desktop Board DG965SS under Windows 7 Beta x64. IntelĀ® Desktop Board DG965SSĀ Audio: IDT* 92XX Driver However, when it goes to configure the driver I get the error: Device Object not present, restart the system and run setup...
BSOD running when running intel driver update utility and more apps
hello sorry if my post isnt great im a newbie here but for some time now ive been getting BSODs and finally figured out how to debug it with WinDbg (x86) and set the symbols for windows but i cant read the text. ive tried reinstalling my GPU and Java but no luck. when i try to run intel driver...
BSOD Help and Support
Old mobo + win7, need driver help.
Hi all, I have an Abit NF7-S2. I know it's ancient in computer years but I NEED to get it working. The built in Lan and sound are the only things not recognized by Win7. I was able to scrounge up all the drivers but of course they don't work with Win7. If I could write my own I would :cry:
Drivers
Help I can't find any Intel D865GLC Audio Driver for Windows 7 32-bit
I was wondering if I could get some help here, I've search all over the internet but I couldn't find any driver for my built-in sound driver. It says it is AD1985. I have an old working driver for it but it is for windows XP.
New MOBO, Which OS to use? Win7 32Bit or 64 Bit?
(first time posting here) Hello! Just picked up an Asus M4A89GTD Pro/USB3 Mobo, 4 Gigs of RAM and using a bunch of old stuff to Upgrade my old 1.8Ghz AMD dinosaur! :-) My question is regarding Which OS should I use? 1. At present I have specialized software (32 bit) for my specific...
Installation & Setup
Intel d945gnt Audio Driver Help
Hi all, I installed Windows 7 Ultimate 64 bit build 7600 on my machine and I'm having a problem with the OS not even recognizing my Audio hardware. I've visited the Intel site and I don't see any available options for drivers there...just the following: RAID: Intel® Matrix Storage Manager...
