Windows 7: Can I run sound through hdmi and rear jack simultaneously?
11 Sep 2013   #1
EndlessDark
Windows 7 home premium 64 bit
I am having a problem with running sound through hdmi from my graphics card and rear jack or headphone jack at the same time. I have to enable and disable the rear jack or headphone jack when I want to listen to headphones. I have a Nvidia 8400gs connected to my tv via hdmi and sound and video travel through the hdmi. When I enable the rear jack sound goes to the headphones but stops going to the tv while both are enabled. Is there a way to get sound to work on both at the same time? Sorry if this is a stupid question lol.
11 Sep 2013   #2
fireberd
Windows only allows one "default audio playback device" (HDMI OR Speakers). Thus if you have an HDMI cable connected it will (in most cases) automatically default to the HDMI. If the HDMI is unplugged it will default back to the "Speakers" (your sound card).
Otherwise, if you have HDMI connected you must manually switch the playback to the Speakers.
There was a 3rd party software program that would allow both in Windows XP. I don't think its compatible with Windows 7 (or Vista or Windows 8) as some of the audio functions are handled differently than XP.
11 Sep 2013   #3
EndlessDark
That's kinda what I thought.. Well thank you fireberd.
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
No sound through speakers.Jack not being detected.HDMI sound only?
So I've got a problem,I changed my case 2 days ago and everything went great,all working as it should be.Up until an hour ago,when the lid got stuck in one of the little clips so after a quick bang it went in.But then I lost my picture on both monitors. So I went to investigate,I ended up...
HDMI Sound Works but Audio Jack Doesn't
I built a barebone kit and installed Windows 7 Ultimate 64bit, I installed all the drivers correctly but for some reason Windows keeps detecting the front audio jack as if someone is repeatedly pushing in and out headphones(no pun intended). Audio doesn't work at all through front and back audio...
How do I use 2 audio jacks simultaneously(front and rear)for 2 systems
I am trying to listen to both at the same time so i can hear double the kick in the bass you know? when i plug both in it mutes the rear and i can only hear the one jack in the front. i have an Emachines windows 7 64 bit Please if you have any feedback i will take it! greatly appreciated:D
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
No audio from rear jack & no hdmi audio
hi guys pretty new here so take it easy plz (lol) i have 2 problems regarding audio. 1. when i upgraded my pc i added a okish motherboard but i wanted sound from my front panel so i took the jumper cap off the prongs for audio but now i have added some desktop speakers and want to plug them...
Graphic Cards
