Windows 7: Sound icon present but sound bars not visible
15 Sep 2013   #1
BC5
Windows 7 Home Premium 64 bit
I have a Dell Studio XPS which has the sound adjust buttons (for volume increase and decrease) on the keyboard. When I press those buttons, the sound does increase and decrease but I am unable to view the bars & I was able to do so previously. I can always use the volume icon on the bottom right hand corner of my desktop, but being able to view the bars by pressing the buttons on my keyboard was more convenient.
Can anyone help me with getting white bars back when these buttons are pressed? Thanks.
16 Sep 2013   #2
fireberd
Sounds like a corruption between Windows and the keyboard drivers. Go to the Device Manager, RIGHT click on the entry for the keyboard and then LEFT click "uninstall" (this assumes you do not have a password to enter to get into Windows when you boot up). Then restart the PC (your mouse will still work) and when Windows starts it will detect and reinstall the Keyboard.
If this does not fix it, the keyboard may be faulty. You can post on the Dell Community Desktop Hardware section and maybe someone there has some additional advice. Desktop General Hardware Forum - Desktop - Dell Community
17 Sep 2013   #3
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by BC5 View Post
Hi BC5,
Welcome to Seven forums.
Kindly follow the steps suggested by fireberd and if the issue still occurs please let us know the model number of the system you have so we can check more details about the same.
Also, let us know if you have updated any drivers or software to rectify this issue.
Kindly update your system specs here by following this.
Keep us posted with the results so we can advise you further.
Audio Drivers Enabled and Visible, yet no Sound.
I have contacted Microsoft previously but all they offered me was an expensive program. My issue is that when I look in device manager, my headphones are enabled, but no sound comes out. In my tray, I see that my sound is muted. I tried to play a song but it gave me an error about my sound. Another...
Sound suddenly not working but audio bars still moving. windows 7
i turned my pc on and tried to watch a YouTube video when i realised there was no sound playing. i tried to play a video file saved on my pc, still no sound. tried an mp3 and still no sound. everything was working fine 24 hours earlier. the green bar on the sound icon in the tray moves when i play...
NO SOUND TROUGH HDMI ON ACER AX3400-U3032 and No HDMI Icon in sound se
Had to replace motherboard from authorized acer parts dealer now I get no sound through HDMI port. I did through the original board until it got fried by electrical surge. Can any one help or send me a picture of the inside the same model to make sure all jumpers on the motherboard are in the...
Windows 7 No Sound. But Mic Bars Full And No Mic Plugged In HELP!
I have tried your usual uninstall update/re install drivers. I have even gone as far as system restore but the problem still exists. So i will start from the top i went out yesterday left my p.c on and its went to standby the usual thing it should do if left running and untouched. When it awoke it...
Sound Icon in Systray will not open Sound Dialog
I recently installed a new Logitech G930 headset on my Win 7 x64 system. It has had problems from the beginning. The problem is the Sound Control will not open when you try to. It is definitely related to the G930 software as if I uninstall it everything is back to normal. At times it may take many...
Realtek drivers no sound present
I have tried many solutions and nothing works,i'm using windows 7,Procesor DualCore AMD Athlon 64 X2, 2000 MHz (10 x 200) 3800+, ASRock ALiveSATA2-GLAN (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN),but my VT8237A High Definition Audio Controller doe's not work. In bottom...
