Windows 7: Sound is not working but its not mute
16 Sep 2013   #1
adriansam
Microsoft Windows 7 Ultimate 64-bit
After 2-3hours my laptop sounds gone. Why?
I have to restart the system for the sound to work again.
Its not mute.
16 Sep 2013   #2
fireberd
Do you have the correct sound driver, from Lenovo? Your System Specs only list "High Definition Audio Device" which suggests the generic, basic function, drivers that are installed by Windows. If this is the case, download and install the correct sound driver from Lenovo.
You did not list the Lenovo Model Number so I can't link you directly to the proper Lenovo driver.
16 Sep 2013   #3
adriansam
I have the correct driver, the installer is from lenovo partition disk
Laptop Speakers is not working but when I plug my headset theres sound.
after rebooting
16 Sep 2013   #4
fireberd
Either there is heat causing the problem or some program that is not releasing the sound after it uses it. Those are the most likely causes.
How do I change sound mute key in W7 Pro
Hi there, At the moment the key to mute sound for me is grave (`) Would like to know how to disable / change this key Thanks in advance
Mute is not working (along with other stuff)
Hi guys. I'm running Windows 7 Ultimate, 32-bit. Running great for about a year now. But I recently noticed this. Pressing the mute key on the keyboard, or muting the system volume (from the volume icon in the system tray) has no effect at all. Whatever sound is being played (e.g. from WMP,...
Why does muting sound in Live TV mute all Windows sound?
Using a tuner card in my computer. When I mute the sound in Media Center Live TV, it mutes all the Windows sound. Any way to get around this? Would like to be able to mute the Live TV & run closed captioning while keeping all the other Windows sounds. Can't seem to find any options to set. ...
Media Center
Can hear sound while mute
Hi guys!I have problem inmy Acer 4736G...When i mute my speakers or lower the volume to minimum i still can hear sounds if i play music or youtube or anywhere if go music...I check the sound option but everything is ok...Pls help!
System Event - Changing sound makes a sound, how to mute it?
Did my searching and couldn't find this one... When I modify the speaker volume using the "Volume Mixer" icon, it generates a sound. When I adjust using the "Speakers/Headphones" icon, it does not make a sound. I would like to mute the Windows 7 sound that happens when I adjust the sound,...
why dose sound turn its self down and then mute
when i launch the windows 7 media center once i try and go to tv live it wants to turn down the volume and then mute the volume :mad:
Media Center
