Windows 7: Possible problem with my headphone port
19 Sep 2013   #1
silentnelite
MS Windows 7 Home Premium 64-bit SP1
About a week or so ago my headphone jack started to act up. I thought it was my headphones that were acting up so I got a new pair (I made the mistake of not checking them on another computer but at least the old and new phones were cheap. ) which also do the same thing. Moving around the headphone's jack causes the computer to start using its speakers again sometimes. When it doesn't do that, sound only comes out of one side of the headphones.
I checked the playback device's properties and both sides are set to the same level. I don't recall updating any drivers recently either. I was hoping to get people's opinion here on whether or not you also think it's an issue with the headphone port (and how I might go about replacing it.)
Thanks!
19 Sep 2013   #2
fireberd
There are mechanical connections in a headphone jack and some even have an extra contact either for sensing or to route the sound to the headphones only.
Most (all that I've seen) PC circuit boards are multi-layer and require special desoldering/soldering equipment to avoid potential damage to the circuit board. Based on what you have posted it appears to be a problem with the jack. I haven't looked at this PC but many have a small board for the I/O and that is the best option - replace that "daughter" boardl
Audio coming from both Headphone and Speakers when headphone used!!
Hello Guys, had this problem while,tried many of the solutions to resolve and failed,finally reset the system to factory settings thinking things will be back to normal,but still it exists!!:cry: *Asus g74sx- windows 7 ultimate,Realtek Hd audio. Just saw the new Realtek Hd audio driver...
Sound coming from both headphone & speaker but headphone is not detect
I have Lenovo 3000 Y410 laptop having Windows 7 Home Premium installed on it. Realtek HD Audio latest driver is installed. But from the last 3 days, when I connect headphone through laptop, following things happen : - 1) Headphone connected popup doesn't show up. 2) Mic of Headphone connected pop...
problems with headphone port and non working speakers Dell Inspiron
The other day a speaker cord was yanked out of my computer and dismembered the head phone port. When headphones or speakers are plugged in they do not work. The main issue here is when nothing is plugged into the port my laptop speakers do not work. Its as if my computer thinks something is plugged...
Right headphone/speaker problem
Hey guys, thanks for taking the time to read. Usually ok with things like this.. but dont know where else to turn.. i ll try map it as best as i can.. i have recently rebuilt a new PC, (old one was kinda dated) everything is running fine.. until i try to use sound on my monitor speakers...
Headphone Jack Problem - Help!
Hello All, my sound output on my laptop (the headphone jack...) is broken, almost certainly a hardware fault, I've tried pretty much everything I know of within windows to no avail. It's only outputting to the right. So, is there any way to configure windows so that it recognises my line-in or...
Hardware & Devices
Headphone problem
Im new to the forums ... looked through a lot of threads for info on my problem. Cant find anything to help me. I have problem with my headphones. They are plugged in blue jack,speakers in green and mic in red. But Realtek HD audio manager cant rekonize ONLY headphone. Mic and speakers works...
