Windows 7: scratching sound even if all sound devices disabled
22 Sep 2013   #1
trogne
In my headphones, I ear a constant scratching sound even if all sound devices are disabled (playback and recording).
Where can comes this sound ?
What can I try ?
Regards,
Patrick
28 Sep 2013   #2
ascomputers
Windows 7 Professional / Windows 8 Pro
its either faulty headphones or your sound card that is playing up.
the issue is usually caused by the grind not earthing out. hence the low scratching buzzing noise.
30 Sep 2013   #3
trogne
OK... thanks. What do you mean by "grind not earthing out" ?
30 Sep 2013   #4
ascomputers
sorry its an old term used to describe when the cabling which receives a voltage or charge through it doesn't ground out. you receive a buzzing noise. feedback.
are you using a separate sound card or on-board? can you borrow a pair of headphones from a friend to see if its the same with there headphones? at least this would isolate the issue as to whether its the card or your headphones.
01 Oct 2013   #5
trogne
"when the cabling which receives a voltage or charge through it doesn't ground out"
I still do not understand the meaning of "ground out".
02 Oct 2013   #6
Faladu
Windows 7 Ultimate Retail Box (64-bit installed) + Service Pack 1
It's not grounding properly, so you get excess noise.
Try other listening equipment to determine if it was the other ones or a deeper issue.
Sound is some how disabled for some programs
For example, I am listening music with iTunes, then when I want to watch a youtube video the sound of the video doesn't work(ofc paused my music@iTunes) I guessed it was me changing something in the audio settings, though I didn't find where I had made the mistake. So, does anyone know how to...
Custom Sound Scheme: Close Window Sound Plays Instead of Chosen Sound
Cheers all, Problem is as stated in the thread; I downloaded, untar'd and set the theme up today. I know it's specifically the "Close Window" sound since it's unique from the others. I'm referring to the following actions in particular (there may be more things I could do to proc it, but I...
on board (realtek) sound disabled with creative card disabled
I have an creative x-fi installed which I have disabled. The on board realtek (mb is an asus ph67) shows audio input to speakers in control panel but no sound at jacks (front or rear). Does the presence of the Creative SC disable the onboard audio?
Sound disabled after downloading Windows 7 SP1
Hi, downloaded Windows7 SP1 on an HP Pavilion laptop and since then get a message that my speakers are disabled (as are headphones). The drivers claim to be up to date, I've tried disinstalling them, updating nothing seems to work....worse still when I tried to run system restore I discovered that...
Disabled a sound device, how to restore it
I have several device outputs, one for my computer speakers and another for my television (which is out through an HDMI). I switch between the two depending on what I am watching stuff on. I right click on the little sound icon on the right side of the taskbar, and click Sounds. It has a list...
Backup and Restore
Sound Disabled After Sleep
Hey everyone - I have a lot of experience in the IT field but this has be stumped. My fiance has a Toshiba Satelite A215 S4747 notebook with Realtek High Definition Audio. As far as I know, it was working fine in Vista. I decided to install Windows 7 Pro 64-bit to take advantage of the proc and...
