Windows 7: Creative Sound Card Problem Thread
11 Jun 2009   #121
velvetman
Windows 7 RC1
Thanks for the suggestion, bloke.
I'll have to try that eventually, the problem is I also can't seem to get system image to work (I have a dual boot with XP on separate drives, but apparently some files for W7 are on the XP drive, so it will only let me create an 80GB image of both drives and I don't have enough space).
So if I start trying these things and they don't work I'm back to formatting, and with everything else working and all my programs (office, CS4, etc) installed and running, I'm reluctant to go through it all again.
I did figure out a temporary solution, though: install the driver and listen to music while I work, then uninstall before restarting. It's a pain, but it works.
11 Jun 2009   #122
oenone
vista ultimate 32bit
i used the betra driver from creative website
now my audigy value is now fine
11 Jun 2009   #123
BuzWeaver
Quote   Quote: Originally Posted by thunder2008 View Post
Hello All,
I have not updated the thread in sometime for working on a design project. Last night I was up into the wee hours doing an installation of Windows7 RC, since learning that the most pivotal software; Solidworks2009 is now functioning in RC.
So, I also have been able to successfully open the x-fi console in this RC build. Have not really had the time to thoroughly test the sound quality, but as yet it seems to work rather well.
I shall update the thread today to reflect everyones continued issues, so that you may also have resolution to your wants.
Please include links as well. I'm going to try a few suggestions that have been pointed out here. I have a Creative Sound Blaster X-Fi Extreme, I've not found the right drivers yet. I'm on an older Pen4 system with 2gig's of RAM running 32bit. My main OS is XP.
12 Jun 2009   #124
joe7dust
Windows 7 Ultimate 64-bit
Is it possible to adjust surround sound balance and/or adjust EQ settings with an Audigy 2 (original) in W7?
The pack I found here does not have the EAX console, which I use to enable CMSS 2 for deeper bass sound as well as more balance towards the rear for more surrounded sound.
13 Jun 2009   #125
BoardBabe
BoardBabe, Creative X-Fi Surround 5.1 USB, Hewlett-Packard HP Pavilion dv5 Notebook PC
16 Jun 2009   #126
thunder2008
Windows 7 RC 7100
Quote   Quote: Originally Posted by BuzWeaver View Post
This is can be easily resolved by using the Windows 7 RC build 7100, if you are using 6100 or previous it will not be possible without a thorough go-around.
Which build are you using?
16 Jun 2009   #127
thunder2008
Windows 7 RC 7100
Quote   Quote: Originally Posted by joe7dust View Post
Joe are you using build 7100? If so you just need to click the compatibility tab for vista to access eax.
18 Jun 2009   #128
joe7dust
I'm actually running 7137 but I think there is something else preventing your suggestion from being possible... When I try to install the Creative drivers from my original CD or the download here the very first thing it says is "no compatible hardware detected" or something to that effect. I guess maybe I can DL the EAX console separately somehow? Kind enough to give me a link? I don't feel like googling this late... *yawn* hehe
18 Jun 2009   #129
Wintings
Windows 7 Pro 64-bit
Since May 29 there has been a new X-Fi Xtreme beta driver available here:
Creative Worldwide Support
Have you tried it? It works fine with my SB X-Fi Xtreme card. Note that it automatically seems to install itself as a "7.1 Surround" system. You will need to go into "Control Panel | Sound" and select ""Configure" to choose the speaker option that matches the audio set-up you actually have.
18 Jun 2009   #130
thunder2008
Windows 7 RC 7100
Quote   Quote: Originally Posted by Wintings View Post
Listen if your running 7137, then that may also be another reason it is doing what it used to do with 6100 builds. As the 7137 while newer than 7100 is nevertheless not a public release.
From what you describe it is doing exactly what it did in the 6100 builds. You should not a that unrecognized driver pop-up at all.
Consider un/re-installing your 7137 to see if this resolves any missing os dlls', that you need. If this does not work then try dl'ling 7100 official not torrent.
Newer x-fi drivers may also help, but they should not be necessary if you have 7100 you could use the manufacturers cd that you originally used with your previous os.
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative sound card not detected
Hi, I have just acquired a creative Audigy 2 Platinum Pro (Model SB0290) from a friend, however Windows can't detect it so I can't install the driver. In device manager a device called Multimedia Audio Controller shows up under Other Devices. Thanks in advance!
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
Problems with my Creative Sound Card.
Hi all, I've been having problems with my sound card drivers ever since I upgraded to Windows 7 64 from Windows Vista 32. I must admit I messed up by not writing down what specific sound card is in this laptop (Dell Inspiron 1520) and I have not been able to find any drivers from Dell.com. I...
Drivers
