Windows 7: Audio problem
25 Sep 2013   #1
unglapungla
Windows 7 Home Premium 64 bit
Audio problem
Hey guys Ive got this irritating problem like when I open a YouTube video while playing Dota 2 , the audio crackles. Anyone experienced this before ?
25 Sep 2013   #2
UsernameIssues
W7 Pro SP1 64bit
Play a flash video on YouTube
Right-click inside of the video
Select Settings...
Uncheck Enable hardware acceleration
26 Sep 2013   #3
unglapungla
Thanks man it worked for awhile. Now though i get some crackling in my audio when i play dota 2. Any ideas why it's happening?
26 Sep 2013   #4
UsernameIssues
W7 Pro SP1 64bit
Perhaps it is not software related. Do you have software that lets you record both the video and the audio of that game? Maybe you could record it - then play it back. If the crackling sound is still there, then maybe you have damaged your speakers.
30 Sep 2013   #5
unglapungla
But I don't use the speakers as I use earphones. One thing I notice is that tho problem only starts up whenever the laptop has been on for a few hours, and I usually just restart it and the crackling is gone. Kinda weird
30 Sep 2013   #6
UsernameIssues
W7 Pro SP1 64bit
When it gets crackly - remove the plug for the earphones and see if the speakers make the same crackly sound.
30 Sep 2013   #7
dexislegend123
Windows 7 Ultimate 64
I have seen this before and helped someone on another forum so after digging here you go.
The problem can occur very well like your playing dota which would require alot from the processor this was the same for someone else on a different game. Yes his problem was temporary solved by restart. This gave me the idea it was more to do with the heavy usage of game causing it.
Method :
1 - Right click the speaker icon in the system tray and choose Playback devices from the context menu.
2 - Highlight your default audio device (green check) and choose Properties.
3- Choose the Enhancements tab and make sure EVRYTHING on this page is unchecked, and then CHECK the option to disable all effects.
Then reboot and see how you go.
02 Oct 2013   #8
unglapungla
Thanks will do,
 Audio problem
realtek high definition audio and high definition audio device problem
Hi everyone, I would be very grateful for some help please! My laptop recently installed a BIOS update - I don't know what this was but since it happened I have been having sound problems with my laptop. After the update I had no sound. I read around and found how to get the sound back on - I...
"Scan for Hardware Changes" fixes audio problem, but problem returns
Hi all, Issue: The sound on my internal laptop speakers does not work when I try to play audio. Solution: However, if I go into "Device Manager" and click "Scan for Hardware Changes" on the "Sounds, video and game controllers" section, my sound returns instantly. The moment I click "Scan..."...
Audio problem, Audio device is disabled.
I turned on my laptop the other day and no audio would play from anything, like youtube videos or itunes. I checked my volume control nothing was muted. When I opened itunes I got a message saying "itunes has detected a problem with your audio configuration. Audio/video playback may not operate...
restart problem BSOD glitchy audio win7 ultimate w/ m audio 1010lt sou
m audio 1010lt sound card not sure why..usually when I shut down it restarts automatically..recently i was watching a movie and it restarted out of no where..any help appreciated.... windows ultimate 7 amd 6000 3.0 ghz processor 4 gb ram I did do some searching i do have m audio 1010lt and...
BSOD Help and Support
Audio problem
Hello all, my audio was working fine for a year, but a few days ago there was no sound, so I restarted my computer and the sound worked for 30 mins or so then went out. I checked to see my drivers were up to date and they were. So then I uninstalled the driver and tried to reinstall one from HP...
