Windows 7: Microphone audio playback issue
08 Oct 2013   #1
haxo512
Hey,
Mic is picking up some weird noises and sound level is spiking all the time in recording devices when mic is not being used and it only spikes when mic is plugged in, seems like something is being played back on mic when nothing is going on. It sounds something like cracking and other loud unexplainable noises that my mic picks up.
Tried messing with settings and default devices/disabling devices and such and no luck.
Sometimes they go away and everything is fine but then noises are back again.
09 Oct 2013   #2
SandeepP
Winndows 7 32 bit
Quote   Quote: Originally Posted by haxo512 View Post
Hey,
Hi haxo512,
It seems like an issue with the mic. Is it a laptop or desktop you have. Do you a mic next to the webcam is using a audio port on the system.
Kindly update your system specs here by following this.
If possible please update the audio drivers for your system and let us know the results.
Keep us posted with the results so we can advise you further.
09 Oct 2013   #3
haxo512
It ended up being mic fault and something to do with cables so i opened it up and made some twists there and it seems to work fine now
10 Oct 2013   #4
SandeepP
Winndows 7 32 bit
Hi haxo512,
Thanks for your reply. Its great to hear that reseating the mic cables have done the trick. Please check the system at your convenience and let us know if you require further assistance.
If you have any further queries feel free to reach out to us.
Search this Thread:
Advanced Search
Unplugging USB sound bar or USB microphone causes playback problems
I am currently configuring a PC with the following setup: Dell Precision T1700 with a E3-1270 3.50GHz CPU and 16GB RAM Dell AC511 USB Sound bar USB microphone line-in and line-out are used by an external device Both USB externals are installed and working. In the sound manager, I have...
Need Instant Microphone playback software
Hello, I'm CrazyKilla I need some SOFTWARE that can INSTANTLY play back my microphone to me, by SOFTWARE and INSTANTLY I mean I already know of the default windows method, it delays the playback and I don't like it.
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
audio playback
Hi all, I have a toshiba laptop with Win 7 ultimate 32 bit installed and just recently started having problems with audio playback. I have 1 gb of ram and approx 40 gb free of my 80gb hard drive. No other programs installed other than virgin security. Problem - after playing mp3s on WMP, audio...
Microphone Low Playback
Hi all, my mic works fine on Skype. It sounds loud and clear on Skype but when I am trying it on Voice Recorder and from the sound options in Control Panel it is very low when I play it back. I have the Microphone and Boost slider set all the way. And I have the sliders set up all the way on...
How do i fix the really low audio playback?
when plugging in my headphones to my pc via my Trust 3.1 sound system or through the computer desktop itself i have to turn it up to insane levels just to hear it at a half decent level? i have no sound card just built in microsoft sound or whatever....
