Windows 7: Audio bit depth not accessible Grey out
11 Oct 2013   #1
Jerry1978
Windows 7 professional 32bit.
hello to all i wonder if there is a way to enable the selection of audio bit depth in the control panel i use Hercules DJ Console Mk4 not as primary i use it with VDJ but the selecion to change from 16 bit 44100 48100 and so on it is not accessible (Grey out) so what i am asking is there away to enable it via the regedit or from somewhere else ''also i has the same problem when i update my Realtek AC'97 Audio''
I hope I was detailed
12 Oct 2013   #2
fireberd
Realtek AC97 is an old audio chip. Current RealTek chips are "HD Audio".
16 bit/44.1Khz is standard "CD quality" audio (what audio CD's use). 48Khz is for syncing with some video. Higher bitrates on playback won't give you any better fidelity. I have a recording studio and record at 24 bit 44.1Khz but the 24 bit is only because I can have more headroom when recording, otherwise 16 bit is just as good. When I mixdown it is to the audio standard 16bit 44.1Khz.
For DJ applications, many song files are in an MP3 format and that is a compressed format and if you convert that to a wav format you will never regain any lost fidelity, it will still be at whatever (something less than full fidelity) fidelity the compressed MP3 file is at.
12 Oct 2013   #3
Jerry1978
thanx You were in great detail
Question for the 32-bit color depth.
Hey guys, I have a question for the 32-bit color depth, before I brought my PC to a repair shop, the windows minimize, maximize and close button looks like the picture 1, but after reformatting it, I re-installed my gfx card drivers, updated MSE, and updated Java (yesterday), and after restarting...
Customization
Out of my depth.
I am having a few problems with my computer running Windows 7 64bit. It has run faultlessly for 2 months, then yesterday it booted to the Windows logo and would go no further, so I restarted and it gave me the option to do a repair which I accepted, it then said it had failed and did I want to do...
BSOD Help and Support
Stuck at 16 bit depth!
I recently installed DVDXPlayer and when I played a video it said something like it didnt like my color depth or something, changed something, it forced my windows 7 to move off the Aero theme and into the basic theme and ever since thing, my videos, pictures, etc look like crap. I have the bit...
Music, Pictures & Video
BSOD - I'm out of my depth
Really frustrated by the ongoing BSOD - No pattern to when I get them (i.e. no particular program running), can happen at various points through day. Running Windows 7 64bit - Original OS (System purchased maybe 8 months ago) - Full retail - System less than 1 year old Let me know if you...
3D could ruin your depth perception
More at original article
Chillout Room
In depth look Windows 7
Given that I knew most of you would be virtually blasted out of your chairs by a “shock and awe” of Windows 7 reviews once the news embargo on the OS was lifted (combined with the fact that I only got my hands on a copy of Build 6801 a couple of days later), I decided to take my time to get to...
News
