Need assistance with FP Audio pins.
  1. Posts : 6
    Windows 8, 32bit.
    Greetings! A time ago I made a thread asking for help about jack remapping in the registry, however, I got suggested to get myself a front panel with jacks. So I did. Got a device with 4USB and 2x3.5mm jacks. I connected all the USB's succesfully, however I couldn't quite made with the pins of the jacks.
    Here's my old thread: IDT Jack Remapping - Anyone familiar?
    Pics of what I got:
    https://dl.dropboxusercontent.com/u/...2023.26.06.jpg
    https://dl.dropboxusercontent.com/u/...2023.26.33.jpg
    https://dl.dropboxusercontent.com/u/...2023.27.38.jpg
    I tried googling the pinouts and followed a diagram, but unfortunately I no luck into it and the front jacks did not work so I unplugged the pins to prevent possible damaging.
    Cheers.
    -George.
    See if this from Intel will help. Usually the front panels have the standard connector, not individual wires like you have.
    Desktop Boards — Front panel audio header pinouts
  3. Posts : 6
    Windows 8, 32bit.
    Thanks, however I tried to follow similar pattern and couldn't get it to work.
    Just need somebody to look at my pins and tell me which where is going.
    And yes, they made it a bit frustrating.
  4. Posts : 8,135
    Rather than spend time with that panel, I would just get a panel with the connector and then all you have to do is plug it in. You may never find out what the pins are in that panel.
    I went through that one time on one of my systems and luckily the Intel chart I referenced had what I needed.
  5. Posts : 6
    Windows 8, 32bit.
    At where I currently am there isn't much of a choice.
    At the store they had this one I currently own, and another one for 44bucks, but I think it was with usb3.0, just 2 of them and it was for the floppy slot of the panel. Can't really remember. I guess I will keep trying.
