Windows 7: Realtek HD Audio Manager, Buzzing noise in playback
25 Oct 2013   #1
warman343
64 bit, windows 7
I've got a headset with a mic and In the Audio Manager i've got the playback volume muted. When i un-mute it there is a faint buzzing noise. thats not a big problem but when i want to talk to friends on skype. I'm really quiet and they can hear the buzzing noise. When I try to use the Microphone Boost, the buzzing gets louder. Its a Deep Buzzing noise. I've done many things to try and fix this, messing around with it, going online to find a fix.
I know its not my headset or my mic causeing it; did a test with another headset.
If this problem has been solved already, please link - Thanks
25 Oct 2013   #2
fireberd
Do you get the Buzz with speakers (only) too? If you hear it with the speakers, physically disconnect the speakers from the PC and then see if you hear it in the headphone - with the Headphone only connected, not the mic.
Do you have any other AC powered device (other than a monitor) connected to the PC?
25 Oct 2013   #3
warman343
64 bit, windows 7
i don't even use/have speakers. i only have my headset with a mic. I unpluged the mic jack and only have the headset jack in and can't hear any buzzing. only when i have my mic active and the playback volume on, there's buzzing.
AC powered device? the only other thing i have is my Hawking Wireless Adapter for connecting to the internet.
25 Oct 2013   #4
fireberd
I assume you are connecting the mic (and headset) to the front panel jacks. Try plugging into the rear jacks (Green for headset and Pink for mic) and see if you have the same problem.
My PC is a Gigabyte Z77 motherboard, with an i7 3770 CPU.
25 Oct 2013   #5
warman343
64 bit, windows 7
having the same problem but the buzzing got louder.
Did some digging and found that my motherboard is a: Ultra Durable 3 Motherboard that has an onboard Accrleration, with Intel core i7 950.
25 Oct 2013   #6
fireberd
See my system specs in the "My System Specs". That is what we need for yours.
Also, are you using the correct sound driver? The one from Gigabyte for your motherboard is generally the preferred driver.
This is what I have in mine. The AMD is for HDMI audio, the RealTek is the PC's sound device The other two are some extras that I have for my Recording Studio.
Realtek HD Audio Manager, Buzzing noise in playback-device-manager-capture.jpg
25 Oct 2013   #7
warman343
64 bit, windows 7
mine looks the same as yours without the two extras.
i'm pretty sure that the right driver is installed, my dad helped me build and install all that i needed.
26 Oct 2013   #8
fireberd
Disconnect the front panel headphone/mic connection from the motherboard (with the PC powered off) and then power on and see if you still get the buzzing. This will help to determine if the problem is in the motherboard or because of the front panel connection.
01 Nov 2013   #9
warman343
64 bit, windows 7
i was trying to see if i could disconnect the front panel, but i didn't because my dad wasn't around and i don't know what cable is what. instead i want to clean up the dust in my fans. after doing that i started up my PC, for a chance i checked if there was any buzzing. i couldn't hear anything. the next thing i tryed was calling my brother on skype. sure enough he couldn't hear it, even if i turn up my mic booster. before i mark this as solved, i'm going to wait a few days just to make sure what ever i did made it stop buzzing.
01 Nov 2013   #10
fireberd
Had to be a cable and possibly the audio cable. Usually, the front panel audio connector is in the lower left of the motherboard.
Realtek Audio Driver buzzing
Hello forum! I have been struggling with this buzzing for such a long time and at this point I think I've tried nearly everything. When plugged my two cables into the rear end of my PC (The pink and the green), it has imense amount of buzzing. A minor fix for this was: install Realtek Audio...
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
Realtek HD audio driver buzzing on windows 7 64
Today i have installed windows 7 on 64 bits and i just cannot get past this problem with the sound. I have a 5.1 surround audio system and have installed the latest Realtek HD audio driver on my pc to get all the speakers going. After the installation of the driver every sound came with...
Drivers
Intermittent popping/crackling noise during audio playback
Hi Everyone: I have a Sony Vaio VPCL23CFX All-in-one desktop computer (See my SPECS). I have an odd problem that I cannot seem to resolve. When I play a song, any song, or any MUSIC, for that matter, I get a popping/crackling noise every once in a while. Sometimes it won't happen for a...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
Static noise on my realtek HD audio
When I pause any audio on my PC I always hear weird noise, like a mosquito, it's so annoying. If you mute - sound disappears, but the more volume you put the louder it is. Any one had similar problems? Or this just means that i need a better audio card?
