Windows 7: Front panel headphone jack problems
04 Nov 2009   #11
shimmy river
windows 7 professional 64 bit
I manged to get 64 bit vista driver for my audio from my mobo's website...then I followed the instructions from darkassain near the bottom of this page....
Asus SupremeFX X-FI
My headphones now work again on the front panel.
I see it as a stop gap measure until some proper Win 7 drivers are released...I tried the BIOS thing....seemed irrelevant to me and didn't work anyway.
Hope this helps
04 Nov 2009   #12
pcxajb
Windows 7 64bit
Quote   Quote: Originally Posted by shimmy river View Post
Shimmy River, any chance you can link the page where you got the driver from? As you have exactly the same motherboard as I do I want to try it too (I'm sure I looked before but couldn't find any updated drivers...)
Glad you are all working now!
05 Nov 2009   #13
pcxajb
Windows 7 64bit
Shimmy River, found the driver (Vista 64bit) on the Asus support website, installed it as per the instructions on the other post, and voila! Front headphones work again.
Many thanks, all fixed
06 Nov 2009   #14
Gibber
Windows 7 (X64)
Still no success
I tried "updating" to a Vista x64 driver from ASUS (ALC882_51005125.zip) but after rebooting I got popups indicating that both ALCMTR and RTHDCPL were incompatible with windows 7, and there was no audio out.
It seems Realtek are releasing a new driver every three or four days. I also tried installing R2.36 from Nov. 2 but it still does not get my audio jack config correct in the RT HD Audio Manager and no audio out the front jack.
Will keep checking here and also Realtek for working solution.
Gibber
07 Nov 2009   #15
uty
Win7 Ultimate 64bit
Hey just wanted to add my 2cents here... Mine was a really dumb "issue" completely due to my dumbness... I've got a Gygabyte GA-MA785GT-UD3H MB with Realtek audio and the issue was that I had to switch in the menu to "Disable front jack detection" and it all worked fine. I read it in the manual for my MB.
09 Nov 2009   #16
pcxajb
Windows 7 64bit
I knew it was too good to be true.....
Headphones work fine since I installed the Vista 64 drivers from the Asus website. Problem now is the front panel microphone (that was working fine before), is now extremely quiet.
I've given up with this and just bought a lead to connect the back panel microphone (which works fine) so my headset can reach for a couple of quid, but there's definitely something still wrong. Was just wondering if anyone else who has fixed the headphones issue (Shimmy River??) is having similar problems with the microphone?
11 Nov 2009   #17
shimmy river
I have to say that I do not use the microphone jack in my everyday pc activity so I haven't really checked it out. I'm now having problems with sudden system crashes (event id 41 - source kernel power). I'm sure it has nothing to do with the vista 64 driver though.
could handle the front panel audio working...but system crashes is another matter..damn
09 Dec 2009   #18
valem888
windows 7 x64
download the drivers for W7 and W7 x64 from
ASUSTeK Computer Inc.
10 Dec 2009   #19
Gibber
Windows 7 (X64)
Which ASUS Windows 7 driver?
Hi Valem,
Further to your suggestion can you be more specific as to which windows 7 driver? I cannot find a windows 7 driver at ASUS for the ALC882 codec on my MB. Note that my MB is an ASUS P5LP-LE which is not found on the ASUS site because it is made by ASUS for HP.
Also I just tried the latest from Realtec, R2.38 to no avail. Still no front panel audio.
Gibber
11 Dec 2009   #20
Its me again
Don`t know if this will help anyone,
My front panel jacks don`t work since my windows 7 upgrade, I read at another website that sometimes the problem is that slightly older pc`s have a different front panel and the new sound drivers for windows7 don`t account for this.
I bought a USB headset , it works fine.
I know it doesn`t fix the problem , but at least im back using my headset and mic again.
Have a nice day
Headphone front jack is far too quiet
Hey Recent problem, basically I've turned up all possible volume controls I can find, tried multiple programs, multiple headphones and earphones, and the problem remains = sound is fine when it's coming out my cheap 2.1 speaker set, but when I use the headphone jack, it's really quiet. It's a...
Front Panel Headphone Jack - Poor feedback issue
Hi! Thank you for taking the time to read this & hopefully help me resolve my issue. May the records state that I'm not the most experienced with computer hardware, but I'm interested in it and have been learning through my friends. That aside, I recently got a Logitech G230 Stereo Gaming Headset....
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Front input headphone jack does not work
I recently run into this problem. The first time I tried to use it, it seems that the green jack for my headphones doesn't work at all. Plug in any pair and they don't even recognize it being there, as seen in Control Panel. What might be the problem? The case has a bad jack, or the connector...
