Windows 7: Front panel headphone jack problems
11 Dec 2009   #21
windows 7 x64
Sorry Gibber,
I had the same problem as U and I saw that Asus made some up for my M2N-SLI deluxe on W7 x64.
I hope that U can find your driver. try to look in Nvidia.
good luck,
02 Feb 2010   #22
High Definition Drivers Worked
Hi All. I had this problem too. I am running Windows7 on a Biostar MCP6PB M2+. My front headphone jack did not work either until I loaded the High Definition Audio Drivers for the board. After that, everything was great. Hope that helps someone.
31 Mar 2011   #23
Windows 7 Pro 64 bit
turn off front panel validation (in german its Front Anschlusserkennung deaktivieren, dunno the correct translation), and bam ur audio is back
08 Jun 2013   #24
Windows 7, 64bit
I had the same problem of dead front panel audio port, i had a go at it several times, tried out a bunch of different stuff, nothing seemed to help, in the end what helped for me was going to asus page, find audio driver for my motherboard, which can be autodetected or manualy selected, download and install it. Attention it did not work even after rebooting my PC!! So lastly with little hope i went to control pannel under sound and devices as with so many previous drivers i installed and uninstalled, found the just installed driver, played a bit with its settings (turning on of different speakers to headphone settings) and suddenly works like charm.
09 Jul 2013   #25
windows 7 ultimate x32
fix: Front panel jack not working on windows
Quote   Quote: Originally Posted by Larryec View Post
I just installed Windows 7 two day ago and since installing, my headphones pluged into my front panel are not working. I have onboard sound with my Intel DP965Lt board.
go to fix: Front panel jack not working on windows - YouTube
07 Jun 2014   #26
05 May 2015   #27
Win 7 64 bit home premium
I installed a soundblaster sound card, after which the front panel headphone and microphone jacks do not work. How do I repair them?
That was the question I was going ask. Then I started looking around the forum and found some hints.
Number one was to look in the BIOS for AC97, but all I had was "Onboard Audio" set to "auto", so I set it "enabled". I guess that enabled the system to recognize the "realtek Audio" on the system?
Then I went to sound control, and voila all of the "realtek audio" was there. Then I made sure all were emabled. Then I tested the front jacks with my Logitech headphone and they worked.
Search this Thread:
Advanced Search
Headphone front jack is far too quiet
Hey Recent problem, basically I've turned up all possible volume controls I can find, tried multiple programs, multiple headphones and earphones, and the problem remains = sound is fine when it's coming out my cheap 2.1 speaker set, but when I use the headphone jack, it's really quiet. It's a...
Front Panel Headphone Jack - Poor feedback issue
Hi! Thank you for taking the time to read this & hopefully help me resolve my issue. May the records state that I'm not the most experienced with computer hardware, but I'm interested in it and have been learning through my friends. That aside, I recently got a Logitech G230 Stereo Gaming Headset....
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
Front Headphone jack..
Hi guys i m new here... need some help. My front headphone jack is not working but mic is working.. Headphone works properly at rear jack. System info. System model - PI945GCM Processor Intel(R) Core(TM)2 Duo CPU E7300 @ 2.66GHz, 2670 Mhz, 2 Core(s), 2 Logical Processor(s)...
No Sound From Front Headphone Jack
Hi, When I first installed Windows 7 on my computer I had to manually install a sound driver. I went to the Dell site and downloaded the only audio driver for my system, Dell Precision T7500. The driver was SoundMax. The onboard sound worked, but the headphone socket one the front wasn't....
Front input headphone jack does not work
I recently run into this problem. The first time I tried to use it, it seems that the green jack for my headphones doesn't work at all. Plug in any pair and they don't even recognize it being there, as seen in Control Panel. What might be the problem? The case has a bad jack, or the connector...
