Windows 7 Forums Search
Windows 7 - Audio from speakers, not from headset, vice-versa.
10-23-2009   #1
sd0
I have 2 speakers, nothing fancy. And a Sennheiser USB headset. Problem is when I set my default audio device to Realtek High Def Audio, my speakers work and my headphones don't. I have to manually set the default device to my headphones, but then my speakers don't work.
Is there a way to have audio through both?
10-23-2009   #2
WCP ONLY
Quote   Quote: Originally Posted by sd0 View Post
sd0
could you give us info on your sound card/chipset so we can go reseach it for you.
thanks
ken
10-23-2009   #3
sd0
I'm using onboard sound on my ABIT IP35 Pro.
10-24-2009   #4
sd0
Hate to bump, but can anyone help me with this?
10-24-2009   #5
Win 7 Ultimate x64
Unless the program has the option of using an audio device other than the Windows default (and a USB headset is a second audio device with its own driver, and fucntions completely independent of whatever other sound card is installed), then what you are looking to do isn't going to happen.
 Audio from speakers, not from headset, vice-versa. problems?
Similar Threads for: Audio from speakers, not from headset, vice-versa.
Solved Quickly switch default audio from speakers to HDMI and visa versa Sound & Audio
File Sharing - Between XP and W7 (and vice versa) Tutorials
Can connect to laptop from desktop, but not vice versa... Network & Sharing
I have to reverse my speakers position. (L is at R and vice versa) Sound & Audio
Sharing files from Seven to Vista and vice-versa Network & Sharing
