Windows 7: How to toggle between default sound device using hotkey
31 Aug 2014   #11
AphoticBass
Windows 7 Ultimate 32 bit
would you guys be able to write a script to toggle between these 3 sound devices?
18 Sep 2014   #12
timmybones
*Edit: I realized after posting the tabbing is lost, which makes the scripts a bit more difficult to read. Here is a link to a text file with the spacing preserved
https://drive.google.com/file/d/0Bwm...it?usp=sharing
The reason the scripts posted so far don't work for everyone is that they are hard-coded to work in a specific scenario for device installation. All the scripts do is try to enable either the first device in the list or the third, whichever it's able to.
This doesn't work for me because my device list isn't arranged that way, and apparently the same is true for others, so I wrote the script below instead to find specific devices (the script is based on the ones posted here but modified, primarily just the loop) (shortcut is windows key + ctrl + s)
#+s::
Run, mmsys.cpl
WinWait,Sound
Loop{
ControlSend,SysListView321,{Down}
ControlGet, device, List,Selected,SysListView321
if InStr(device, "Speakers")=1 {
ControlGet, isEnabled, Enabled,,&Set Default
if isEnabled {
found:=1
break
if InStr(device, "m/m")=1 {
if isEnabled {
found:=1
break
if (found)
ControlClick,&Set Default
ControlClick,OK
WinWaitClose
SoundPlay, *-1
return
That looks for devices called "Speakers" or "m/m" that are not currently the default and sets the default to the first of those two it finds. You can modify this to work for different device names, just edit the "Speakers" and "m/m" strings in that script as needed.
In cases like AphoticBass' where multiple devices have the same primary name, you will need to add a tab after the primary name in the string and then include text from the next line as well to get a unique name to look for, e.g. "Speakers<tab>SkullCandy" for the screenshot above (I can't actually insert a tab in this post, so <tab> should be the actual tab character).
AphoticBass - to do what I believe you really want, the script below will just cycle through all eligible devices, so you can use it to go through your three as needed (this will work for anyone else with any number of eligible devices in the list, though). (shortcut is windows key + ctrl + d)
#+d::
lineCount:=""
defaultLine:=""
found:=""
isEnabled:=""
line:=""
Run, mmsys.cpl
WinWait,Sound
;we'll need the total line count later
ControlGet, lineCount, List,Count,SysListView321
;find which device is the current default
Loop {
ControlGet, line, List,Selected,SysListView321
if InStr(line,"Default Device")>0 {
ControlGet, defaultLine, List,Count Focused,SysListView321
break
;need to stop if we get to the bottom
ControlGet, line, List,Count Focused,SysListView321
if (line=lineCount) {
break
if (!defaultLine) {
MsgBox Error: couldn't find a default device currently in use.
return
;find the next eligible device in the list after the default
Loop {
if (isEnabled) {
found:=1
break
break
if (!found) {
;if we are here we didn't find another eligible device later in the list,
;so need to start at the top again
Loop, % lineCount-1 {
ControlSend,SysListView321,{Up}
;start back down the list
Loop {
if (isEnabled) {
found:=1
break
;need to stop if we get to the bottom (this would mean something is wrong, though)
break
if (found)
ControlClick,OK
WinWaitClose
SoundPlay, *-1
return
I just learned AutoHotKey tonight and handling cycling back to the top of the list is not really trivial based on how this language works, so let me know if you run into any issues with the script. It worked for me, but I didn't do very extensive testing, and only tested on one machine.
23 Nov 2015   #13
BurnOmatic
Windows 7 Pro
this right here works beautifully https://code.google.com/p/audioswitch/
Default Sound Device changes on restart
I'm having a slight problem here, Windows 7 Ultimate. I'm set up with two monitors, the second with HDMI, but I have default sound as the speaker/headphone outputs on my motherboard. For some reason everytime I restart my computer it defaults to HDMI for audio and I need to switch it back, kinda...
hotkey to disable an audio device of choice
How would I add a hotkey to toggle on/off an audio device of choice in Windows 7 x64? Here is an image of Windows 7 sound dialog window > playback tab to audio devices. reason being: skype doesn't have a default audio device as an option so I switch between headphone (reciever) to speaker...
General Discussion
default sound device is disable
Good Day to all of you. I am a new here and was trying to search for may problem which could not find the related issue. I tried to change the default playback on my laptop but the option "set default" is disabled and could not be changed. Hence, please help how could have it enable, I have...
Mbox 2 + Windows 7 Default Sound Device
Hey everybody, So i was just wondering if anybody here could help me with this problem. I have a Digidesign Mbox 2 which i use as my external sound card for music production, i just upgraded from XP to Windows 7 64 bit and while the external sound card works for Pro-tools and my other audio...
How to set default sound playback device
Hi, I have system with multiple Sound playback devices. Most of the time it needs to be on the first entry in the list of devices (HDMI output with me). I'm looking for a way that when I have manually set it to another device in the list, and then shut down the pc that at the next boot it...
Changing default Sound Device
Is there any possibility of changing the sound device programatically in Windows 7? Or atleast to make the device as the default sound device during installation? In Vista, I could use SetupPreferredAudioDevice key in INF file to make it as default at the time of installation, but I could see...
