Windows 7: No audio output device is installed...?!
08 Nov 2013   #1
mickelsen
windows 7
I'm doing a complete installation of Windows 7 32-bit. So far everything seems to be going well except for the sound. There is none. The little icon over on the right side said "No audio output device is installed". So I went to the Internet and downloaded the package for Realtek. BTW, the sound "card" is built into the motherboard. I did the installation, following all of the instructions, and then rebooted the system as it said to do. When the system came back up it still said "No audio output device is installed".
Would anybody have an idea as to what I've done wrong or what is wrong with my system? I would really appreciate the help.
Thanks,
Mark
08 Nov 2013   #2
Golden
Microsoft MVP
Windows 7 Ult. x64
Mark,
Have you tried installing the drivers that would have been bundled with the motherboard installation DVD?
09 Nov 2013   #3
boohbah
try running the ms audio trouble shooter.
i recently updated to 8.1 from 8 and my audio went.
i ran this and it showed nothing to fix but afterwards my sound was back , so worth a try...
No sound in Windows - Microsoft Windows Help
although the page says win 8 or 8.1 its the same troubleshooter for win 7
16 Nov 2013   #4
rvcjew
7 Pro x64, 10 Pro x64
what does your device manger look like? any errors?
17 Nov 2013   #5
mickelsen
windows 7
I solved my problem. I found that the audio hardware was disabled in the BIOS. I enabled it and everything is working fine now.
26 Feb 2014   #6
daveheyman
Windows 7 Home Premium 64bit, 6.1.7601 Service Pack 1 Build 7601
I used the troubleshooter and it fixed the missing audio device. Right click the audio icon if is in your task-bar and the troubleshooter option is on the top of the pop-up window list. If you don't have the icon in task-bar go to control panel, then sound. Thanks boohbah!
No Audio Output Device is Installed
I believe this is an issue regarding an update. I had this issue before and did a system restore to back before I had installed a certain program, and the issue went away. Now however, I do not have a restore point that will go far enough back. I started up my computer today and I was hit...
Drivers
no audio output device installed
This is my wife's sony vaio, and she has had this problem with no sound on her laptop, when checking the volume control it says no audio output device installed. In device manager it says that she has Intel display audio. I need major help here please.
No AUDIO OUTPUT DEVICE IS INSTALLED
No AUDIO OUTPUT DEVICE IS INSTALLED, this is the message l got on sound icone since l installed windows 7 l have downloaded it several time the latest one it shows on control panel but not on device manager, l guess this is not really installed but l keep installing it and restat the laptop...
No audio output device installed
I bought a generic computer. It had windows vista installed and it used to display a message that No audio output device is installed . I recently installed windows 7 home premium 32 bit on it but it still says the same thing. I went to properties of it and found following error message.This device...
No audio output device installed...Tried everything, need some help.
All fixed...Hardware issue. Stripped it down and rebuilt it. Booted up and installed the drivers....woohoo I have sound again...lol Hi, I have had this problem now for a couple of months. What I have tried: Reinstall windows 7 Update bios Install the realtek high definition audio...
Realtek Audio: No Audio Output Device is Installed
Hello. Im having the dreadful "No Audio Output Device is Installed" problem on my realtek audio. It worked some months ago, but im in no position to do a roll back. Im sure the hardware is just fine, it works with Ubuntu. The computer is a Dell Vostro 430. My OS is win7 64bit. I tried...
