Sound will play from headphones but not speakers. (Desktop)
I was having some issues with my harddrive having a memory leak and it was running out of space. I tried to install a Nvidia driver and everything got screwed up on my computer. I use a sli system with two video cards. I didn't realize at first it was my harddrive, so I switched the cards ports and later managed to get the video driver to install correctly after clearing space on my harddrive. My physical speakers have not worked since.
I can get audio to play perfectly now from my headphones, but my speakers will not play sound no matter how hard I try. I've tried making sure they're enabled, I've tried re-installing the audio driver multiple times. I've tried everything I can think of with my sound settings and I can't figure out what's going on. My physical speakers are a surround sound system. I have 3 ports (black, orange, green used right now) that my speakers use. The computer detects that these are hooked up in the realtek control panel (ports are highlighted while the rest are transparent).
In order to rule out an actual issue with the speakers, I tapped the tips of the plugins for the speakers and it reacted to tapping with sounds from the speakers.
I've cloned the harddrive to a new fixed one with a higher memory capacity since this problem started. I did a test for corruption with command "sfc /scannow" in run and found nothing. The new harddrive hasn't fixed the problem.
Any ideas?
