Windows 7: Sound will play from headphones but not speakers. (Desktop)
09 Nov 2013   #1
Malkirion
I was having some issues with my harddrive having a memory leak and it was running out of space. I tried to install a Nvidia driver and everything got screwed up on my computer. I use a sli system with two video cards. I didn't realize at first it was my harddrive, so I switched the cards ports and later managed to get the video driver to install correctly after clearing space on my harddrive. My physical speakers have not worked since.
I can get audio to play perfectly now from my headphones, but my speakers will not play sound no matter how hard I try. I've tried making sure they're enabled, I've tried re-installing the audio driver multiple times. I've tried everything I can think of with my sound settings and I can't figure out what's going on. My physical speakers are a surround sound system. I have 3 ports (black, orange, green used right now) that my speakers use. The computer detects that these are hooked up in the realtek control panel (ports are highlighted while the rest are transparent).
In order to rule out an actual issue with the speakers, I tapped the tips of the plugins for the speakers and it reacted to tapping with sounds from the speakers.
I've cloned the harddrive to a new fixed one with a higher memory capacity since this problem started. I did a test for corruption with command "sfc /scannow" in run and found nothing. The new harddrive hasn't fixed the problem.
Any ideas?
09 Nov 2013   #2
fireberd
Check the Control Panel/Hardware and Sound and finally the Sound Panel. Your "Speakers" (the RealTek) should be set as the Default Audio Playback device. If not, you will not get any speaker sound.
As you installed NVIDIA and whatever with the video, the HDMI may have been set as the default playback device, and in this case the headphones would work but not the speakers.
09 Nov 2013   #3
Malkirion
Yea, I've tried going through and changing default devices. Trying to "test" any of the devices in playback is what I was doing to try to see if it was working at all. Whenever I try to "test" or "configure speakers" and do the sound test, it plays no sound at all, but will work perfectly when I have a headphone plugged in.
I've gone through and switched the speakers off and on as the default device and I've also gone into the sound options in the bottom right taskbar switching between what sound should be playing though, nothing has helped this issue. :/
10 Nov 2013   #4
fireberd
I assume you are plugging the headphone into the front panel speaker jack. Try the headphones in the rear Green speaker jack and see if you hear anything.
10 Nov 2013   #5
Malkirion
Hmm, well the headphones work by usb. The speakers work by the green, orange, and black jacks in the back. I'll try to see if plugging in a regular set of headphones into the speaker input works later today though.
10 Nov 2013   #6
Malkirion
I tried plugging headphones into the jack. The computer gave me a notice that i had removed items from the audio jack. I then plugged in my headphones, the computer let me know that something had been plugged in. Started playing a video....no sound.....so the computer is recognizing the jacks....everything is enabled....yet it's still not playing sounds....I'm baffled here...
11 Nov 2013   #7
fireberd
Something else to check. Since you were inside the PC, check the front panel headphone/mic connection on the motherboard. It may have been disturbed. In fact, temporarily unplug that from the motherboard and see if that makes a difference.
The USB connected headphones doesn't utilize the PC's sound device output so that can be throwing you astray.
Speakers and headphones play at the same time?
I think it was working fine yesterday but today both are working at the same time.. I've tried rebooting but the problem still happens.
Speakers play when headphones are plugged in
My Speakers play when my Heaphones are plugged in I have looked at previous solutions such as going to search and sound and changing to default. But on my control pannel of sound I only have the options of Speakers and Bluetooth Headphones not Speakers and Headphones as I assume I am supposed to...
Play some sounds through speakers and some through headphones
Is there a way to do this?
Speakers play ONLY when headphones are plugged in
Hi everyone, I have had this problem for a while now not sure what started it though. My Acer 1410 Laptop speakers only will play when the headphone jack is connected to something. It seems that it is confused on when headphones are plugged in and when they are out. I have tried to uninstall and...
Headphones and speakers play at the same time
So, my problem is that both the speakers and the headphones play in my HP laptop at the same time. When I go into my playback devices I have three options: 1. ATI HDMI Output 2. Speakers and headphones (same device) 3. headphones When my headphones are connected the third still shows...
want different sound through speakers and headphones.
ok, so i play MMO's and i want my Ventrillo to come through my headphones through the front jack's, and i want all my other sounds to come through my speakers. i cannot figure out how to get it to work like that. i had it no problem with XP but i just went to windows 7 ultimate last night.
