Windows 7: RealTek sound not recording
11 Nov 2013   #1
sparkfishes
windows 7
I can not make narration files for Windows Movie maker ( not liveMM)
I can not record using Windows recorder
The sound from my microphone comes out of my monitor speakers ( I don't think it should) and it has a echo sound
If I go to the RealTek controls the microphone level bar does move when I speak into the micro phone
but if I go to Windows recorder or Narration record in WMM it does not show any input
I have made several narrations in WMM in the past so I know it did work .. once, and I feel it is a RealTek set up rather than WMM and W sound Recorder problem.
I have spent a couple of days on it now
My Realtek information is: Audio driver 6.01.5874 DiretX 11.0 HD audio Audio Codec ALC662
11 Nov 2013   #2
fireberd
The mic sound normally will come out of the speakers and the reason many use a headphone when using a microphone with applications such as Skype or on-line gaming. You will have to turn the volume down on the speakers.
As the microphone appears to work, but is not recorded, it could very well be that the programs are trying to record from the "Stereo Mix" and you do not have that or its not set as the default recording device. With the Stereo Mix set, then any recording device will be heard/recorded including the microphone, Line In and streaming audio from the Internet.
To see if you have the Stereo Mix and if its set, go to the Control Panel/Hardware and Sound and finally the Sound Panel, Recording section. If the Stereo Mix is shown, but disabled or not set as default, enable it and set it as default recording device. If its not shown, RIGHT click in a blank area of that panel and then click to show Disabled and Disconnected devices. Stereo Mix should now show up and you can make it the default.
If Stereo Mix is still not available, it could be your PC vendor has disabled it. You did not include your PC make and model number in the My System Specs (or motherboard vendor/model number if its a custom built system).
11 Nov 2013   #3
sparkfishes
windows 7
Thanks I will try this to morrow
I have made may narration recoding before so I think that rules out any PC/ Motherboard blocking from new
I do have steel mix clicked ......are you saying turn it off?
My desk microphone and headset mic are on the plug in jacks not the in line phono plugs
10:00pm now ......nearly my bed time!
12 Nov 2013   #4
fireberd
No Stereo Mix (may be called System Mixer) is needed.
I was gone yesterday so I couldn't respond (I'm a musician and had a music job last evening).
Can you post what you show in the Device Manager for Sound? You should have an entry for the RealTek and if you have HDMI capability an entry for the HDMI audio. If you have something such as "HD Audio Codec" that usually indicates the Windows installed generic sound driver and that could be interferring. If this is the case, uninstall the HD Audio Codec in the Device manager then restart the PC and check to see if the sound recording works.
To uninstall a device in the Device Manager, RIGHT click on the entry to highlight it and then LEFT click "Uninstall".
If there is only the RealTek (and possibly HDMI) in the Device Manager, using the uninstall procedure above uninstall the RealTek, DO NOT check the box to also uninstall the driver, then restart the PC and when Windows starts it will detect and reinstall the sound. If there were some type of corruption this will usually fix it.
12 Nov 2013   #5
sparkfishes
windows 7
Thanks for your help .I am almost up as running now.
My problem was steel mix was disabled .....I can get a voice recording now in Windows Movie Maker .......but it has an echo effect
I have found the environment effects drop down I will change that from generic to room and see if the echo goes away.
I am most grateful for your help. Off topic : my son's father in law is a professional English folk singer ......look him up on Google
Vin Garbutt
12 Nov 2013   #6
fireberd
Great, I didn't offer much, but glad you got it straightened out.
Realtek ALC883 - recording issue
Hey all, Relatively a newbie with Win 7, much preferring from Vista though, but I have an odd problem, I did do a search and see a few people had the same issue, but not quite the same as my issue. I have an Asus P5K-PRO board with onboard sound (Realtek ALC883). I have installed the drivers...
Distortion sound using onboard realtek sound card on windows 7ultimate
Hello,i recently upgrade my system from xp to windows7,i use the same realtek driver and get distortions!I try severall drivers,disable all enhancements/levels on speakers properties with no result(2.1speakers-),i configure them in stereo mode,i reduce the default format to 44100 16bits(cd...
No sound, Realtek sound inputs assigned randomly
The realtek audio managers shows that the front two inputs, front mic and headphones, are always plugged in when there is nothing in them at all. When I plug in my speakers to the back green input for sound it inputs both the green one, front speakers out, and the blue input, line in. Now I get...
sound recording
I have the following problem: I see only ONE Recording Device: Microphone, not Line In or Phone LIne. I have VM running and there I can seen ALL Recording Devices. I have the latest Software updates from ThinkVantage System Update. My configuration is as follows: IBM Thinkpad Lenovo Z61m...
[Recording] Stereo Mix Available, Sound Recording Not
Hello. I am EpicallyAWSM. Alright before I explain, I must tell you that I WAS able to record audio previously. I'm having a problem while recording audio with Fraps (a game video-recording software). Previously, I was unable to find the Stereo Mix at all, until I found the Drivers CD that...
Recording Sound ??
Hi, Os: Windows 7 ultimate I want to record sound that comes from my speakers, I have right clicked the speaker icon on the taskbar, gone to recording devices, then right clicked to show disabled devices but there is no sound mixer. My sound card is: audio device: Creative X-Fi Audio Processor...
