Windows 7: intel 82801 DB/DBM AC'97 audio controler problem
23 Oct 2009   #1
Windows 7 Tiny
Hi.
I'm Chris. I've got some problem with Windows Tiny 7 version.
The problem is sound. I've already installed realtek audio controler
that is recently released by realteck as windows 7.
Actually, It's working, but the sound is very very lower~
I can't listen to music something like that.
Do you have any idea my problem?
Here are some screenshot with sound card.
intel 82801 DB/DBM AC'97 audio controler problem-1.png
intel 82801 DB/DBM AC'97 audio controler problem-2.png
26 Oct 2009   #2
First I wouldn't reccomend using an un-offical build of Windows 7...these tend to be loaded with problems
Second...try this
Right-Click volume icon->Playback Devices->Right-Click Default Speakers->Properties->Enhancements tab->Enable Loudness Equilzation
See if that helps the low volume. If that doesn't work than reinstall the AC'97 drivers as an Administrator Run as Administrator
Similar help and support threads for2: intel 82801 DB/DBM AC'97 audio controler problem
Intel 82801 DB / DBM USB 2.0 - 24CD Drivers
Intel 82801 PCI Bridge - 244E <-- Help Drivers
help with crysis 2 controler problem Gaming
Solved HP ZD8000 mass storage controler Drivers
Audio Problem with Intel G41 Sound & Audio
Intel Sata controler ICH10R AHCI + Jmicron AHCI error Drivers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33
