Windows 7: Help, no rear sound or microphone front or back!
23 Oct 2009   #1
Vista 32 bit ultimate
I have a Gigabyte ma770t-ud3p board and My headphones and stuff were working fine until my realtek kept asking me if i was plugging things in even when i wasnt, now my rear sound ports dont work and my microphone ports wont work either, When i went into the Realtek jack information the plug for the front and back microphone port is lit up.
25 Oct 2009   #2
Go ahead and install the latest realtek drivers for your sound card.
Search this Thread:
Advanced Search
REALTEK|using front speakers through rear output jack - possible?
hi Every time I wanna use speakers instead headphones,I have to use the same headphones output (green one - back panel), and therefor to disconnect and connect cables.. not very comfortable I've tried to use the black output, and it worked, but only as a 'rear speakers', both left and right...
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
Cannot record from front or rear jack
W7 does not seem to recognize front or rear mic jacks. Tried with 2 mics, one brand new, I am using built in W7 recorder. Thanks, Luis.
Rear'Microphone' and 'Line in' Sound recording devices are unavailable
Good morning all. Could anyone please explain to me how to enable my rear 'microphone' and 'line in' devices in win7 64? Currently they are listed as unavailable(see attached image). The rear 'microphone' input socket has a guitar physically plugged into it, and the 'line in' has a stereo synth...
No Audio Output via Front and Rear Jacks
Hey guys, I installed the Hyper 212+ this weekend, but after installation, the audio stopped working. Thinking that this was a hardware issue, I went back and replugged some of the cables back into the mobo to make sure they were securely in there. No luck. My setup (other specs in profile):...
Mic not working in front or rear panel.
Hey, my headset was working fine in Windows XP but ever since I upgraded to Windows 7 it hasn't worked, I've tried pretty much every setting in the Realtek command center, updating drivers and so on but nothing seems to work, all I can record is static noise :mad: Any chance someone can help me...
