Sound Cards **That WORK**
Page 1 of 9 123 ... LastLast
  1. Posts : 34
    Windows XP and Windows 7
    I'm after a list of Sound cards that people absolutely know work in Windows 7 (beta build 7000) and have drivers that support them which also are compatible with Windows 7.
    Thanks for any support/help.
    List of Sound Cards and Drivers that work:
    -Creative Sound Blaster Audigy 4 (Drivers Located here)
    -M-Audio's Delta 1010 LT soundcard with drivers made for Vista SP1, with Windows 7's compatibility program (All Delta series may work with Vista SP1)
    -Asus Xonar D2 sound card works, Recording features may not work in some with some driver software.
    -Sound blaster Audigy 2 SE works with the drivers from windows update
    -Soundblaster live, only with kxproject drivers. WARNING: The windows update drivers give terrible sound.
  2. Posts : 1,633
    Win 7 Ult SP1/Win 10 Pro (all x64)
    Creative Soundblaster Audigy 4 for starters
  3. Posts : 34
    ^Update^
    And any information is valuable.
  4. Posts : 184
    windows 7 64bit
    nvidia geforce 9400 works fine with out of box drivers
    that is all
    Msongs
  5. Posts : 8
    My Asus Xonar D2 sound card works but none of the recording features are usable in my driver software any longer.
  6. Posts : 67
    Windows 7 x64
    Sound blaster Audigy 2 SE works with the drivers from windows update.
  7. Posts : 34
    Cheers guys, its been updated.
  8. Posts : 35
    Windows 7 - 7000
    All Conexant
  9. Posts : 34
    juanpablo1313 said:
    All Conexant
    Got any information on that?
  10. Posts : 2
    Windows 7 & XP Pro
    This thread should be stickied...because of Soundcard probs I'm using W7 less & less...
