Windows 7: Prevent W7 Switching Audio Device When Connecting/Disconnecting USB De
16 Nov 2013   #1
Swiftkidd
Windows 7 Ultimate 6.1 x84
Everytime I connect or disconnect a USB device my default audio device changes to a different device.. anyway to prevent disable this from happening.. I use USB mostly to charge my smartphone and only occasionally to transfer files but it is an annoyance as not only I have to change the default device but have to restart flashplayer or videos on media players because it can't recover from change.
16 Nov 2013   #2
rvcjew
7 Pro x64, 10 Pro x64
is your phone capable of being a DAC if not it should not be changing your playback options at all. that's odd what is your phone? does it do it when you just plug in any flash drive, and what is it changing your playback device to?
17 Nov 2013   #3
Swiftkidd
Quote   Quote: Originally Posted by rvcjew View Post
My phone is HTC Desire but it also occurs with USB Flash Drives.. It changes from Line1 to SRS Audio Sandbox
17 Nov 2013   #4
rvcjew
did you install srs sandbox it seems to be a software EQ. also why are you using line 1 vs your speakers what does line 1 go to?
18 Nov 2013   #5
Swiftkidd
Yeah, I use SRS Audio Sandbox in combination with Claesson Edwards Breakaway which is shown as Line 1. I use headphones 95% of the time so I like the added depth, bass and simulated surround sound from equalizers. Line 1 (Breakway) outputs to SRS Audio Sandbox which then outputs to Realtek HD Audio Output. I can't recall if Windows 7 behaved like this prior to installing the Audio Enhancement software but I plan to fresh format soon so I guess I'll find out
Default Audio Device keeps switching using Razer Virtual Surround.
Hey, everyone! This is kind of hard to explain so I have a YouTube video below, but what I'm trying to do is to lock the default the Razer Virtual Surround device as the default sound device, but I can't seem to make that happen. I've looked everywhere for the past few hours and I can't find...
Connecting to Wireless Router keeps connecting and disconnecting
Hello Guys, I am having trouble with my wireless connection. It was working fine till a couple of days back and then started acting up. Let me explain the problem in detail. System connects to the router. It shows full signal. After 10-15 seconds the wireless gets disconnected. After that the...
Network & Sharing
not plugegd in onboard audio device after disconnecting external audio
I have an Echo Audiofire4 firewire device, for some reasons I need to constantly switch between Echo and my onboard audio device (realtech sth). I remember I could do it in the past, but due to the Echo installation problems I disabled it from windows startup menu and now, though I enabled it...
Audio device and Mouse keep disconnecting, and reconnecting
Ever since i started using Windows 7, my mouse and my audio drivers seem to keep resetting. I have made sure all my drivers for all my Windows components are up to date. I was using the built-in RealTech audio that came with my Asus P8Z68V motherboard, and every few minutes I would see the...
Hardware & Devices
prevent screen-shutdown when switching user.
Is there a way that i can prevent the computer from turning off the screen while switching user? My screen reacts really slow when it gets turned off, then on again by the computer, so its just turns black for ages.
General Discussion
Avoid Disconnecting from the Network when Switching Users
Hi All! Thanks for reading this. Can anyone tell me how the hell can we avoid to get disconnected from the network when switching users? I have two accounts (one for me, one for my girl). For ex., I connect to my company's VPN and when I switch to my girl's account, I get disconnected from...
Network & Sharing
