Windows 7: 1 or more audio services not running
20 Nov 2013   #1
logybe
7 Ultimate 32bit
I went to trouble shooter and when prompted I attempted to start them. The attempt failed. I am lost. I have Windows 7 Ultimate 32bit
20 Nov 2013   #2
logybe
7 Ultimate 32bit
Audio issue continued
Now it also says hardware changes may not have been detected. Just cannot get audio services to run.
20 Nov 2013   #3
logybe
7 Ultimate 32bit
Audio solution
I wanted to put a green check on my post because someone's advice helped on that page. Don't know how to put a green check mark.
Services running
I notice these 3 services are always running. Is it necessary or can I disable them?
General Discussion
Update services not running
Hello! Just finished a reactivation of Windows 7 Pro and now update manager is not working properly, had to reactivate after cloning and upgrading hard drive. I tried restarting the system as the update manager directed me to do. I have tried running the "System Update Readiness Tool" from...
Windows Updates & Activation
Services not running (svchost.exe isn't starting)
Hello everyone, Today, my computer just finished installing updates, and was waiting for me at the user selection/log in screen when I checked on it. I powered it off by holding the power button down to change some BIOS settings. (In the end, I did not save any changes to the BIOS, so I can rule...
Hardware & Devices
Is this too many services running?
I don't know how you can see how much memory a service is running, ( Does it relate to the amount of memory a Process is taking? ) but I noticed I have alot running. Could this large amount be slowing my computer? Is there a program that will scan for shady Services, or show me which ones are using...
Performance & Maintenance
What services do i need running ??
if this does matter , im just a home user dont use fax machine (printer will be) i dont do anything in the way of office work mainly surf the net so im sorry but i took pictures of my services , but is there any on here that are just bieng used and dont need to be ?? i have put the pictures...
How many services do you have running after startup?
Hi all Just curious to know how many services people seem to have running once they have booted up. I have just done a fresh install and i find myself having 41 processes running after startup. I have gone through the menu and set a few to manual as things like the team viewer service etc i...
