no sound out of earphone jack
  1. Posts : 101
    win 7
    I have a Dell insprinon 17r n7110. I have good sound out of speakers, but nothing out of earphone jack, is there a fix for that...I prefer to wear earphones as the sound irritates my wife(but that is an other story)
    would appreciate any help I can get
    Kas
    win 7 ultima
  2. Posts : 2
    Windows 7 Ultimate SP1 x64
    What I would suggest as the first point of call is to check to make sure the sound drivers for your chip set are installed correctly. You can do this by:
    Start
    Right Click on Computer
    Manage
    Device Manager
    From here you will need to scroll down and see if any categories have a 'yellow' triangle next to them. If they do this means that there is a problem with the current driver configuration and you have the option to update this trough Windows Update, or alternatively you can do some searching online for updates drivers, based on the chip set you have.
    As well as this, some Audio Drivers come with their own software. If this is the case in your situation, if you load up the software and plug the headphone jack in to the front header, does the software pick up that a jack has been plugged in? Let me know how you get on
  3. Posts : 8,135
    I assume this is the same PC that was taken apart. There is probably a connector somewhere that was missed or not properly connected. And, if you reinstalled everything, you need the Dell supplied sound driver. Non-Dell drivers in many cases will either not work or not work correctly.
  4. Posts : 101
    win 7
    Thanks to all who chimed it. Installing the correct driver from dell did the trick...now I have sound from the speakers and the headphone
    Soo this problem is solved
    Muchas Gracias
    Kas
  5. Posts : 1,007
    Winndows 7 32 bit
    Muchas Gracias
    Kas
    Hi kaschiro,
    Its great to hear it worked fine after re-installing the drivers for the system. For future if you wish to update drivers for the system you can check this video below:
    Updating Dell Drivers
    Keep us posted with the results so we can advise you further.
