Windows 7: Sound no longer works
30 Nov 2013   #1
websquad
Win 7/Pro 64-bit
After the last update from MS, my sound no longer works. I rolled back to the last restore point, and then to the one just prior to that. Still doesn't work. I've changed no drivers in a long, long time.
Suggestions?
30 Nov 2013   #2
fireberd
What is the status of your sound "card" in the Device Manager? Does it show working OK or does it have an error code.
If it is shown as working OK, RIGHT click on the entry for the sound device and then LEFT click "Uninstall" DO NOT check the box to also uninstall the drivers. Restart the PC and when Windows starts it will detect and reinstall the sound.
30 Nov 2013   #3
websquad
Win 7/Pro 64-bit
Tried that. It uninstalled the drivers, and, after a restart, a pop-up indicated that the drivers were (re)installed. Still no sound. I unplugged the speakers, and that was accompanied by static in the speakers and very brief 60Hz hum. So I know the speakers are working. My rig has an EVGA 780i 3-Way SLI motherboard. I have no separate sound card. There is a cluster of 6 mini jacks in the back -- the green one is where I was plugged into (and have been since I owned the machine), but I plugged it into the other jacks, and still got nothing. Left it plugged into green.
I fired up a YouTube video and noticed on the main Volume Mixer control that Internet Explorer is getting sound (there's a volume bar -- pseudo VU meter -- pulsating). System Sounds is off (as expected), but device Speakers is also pulsating.
Any more suggestions?
30 Nov 2013   #4
AmericanPharaoh
Windows 7 Home Premium 64-bit
Hello Websquad,
Have you tried the Windows Troubleshooter?
Start Orb>Search, Troubleshooting. Hardware and Sound. Playing Audio.
John
01 Dec 2013   #5
websquad
Win 7/Pro 64-bit
Got the response "Troubleshooting couldn't identify the problem."
NEW INFORMATION: I remembered a front panel audio jack -- plugged into that, and sound works fine. So it is a hardware problem. Yikes.
Thanks for all the help!
USB 3.0 no longer works
I bought an HP Pavilion 2 years ago. AMD A-10 proc with 8gig mem. Worked fine for 6 months. HDMI quit working. Started using VGA. Bought Seagate USB 3.0 2 TByte for backup. Worked fine. 18 months later MSI MS-7778 motherboard started giving me trouble on start up. I'd push the power button...
Hardware & Devices
Internet Sound No Longer Works On Some Sites
I am new so forgive me if this post is not in the correct area. I have the latest Internet Explorer and have recently installed Avast (may or may not be relevant), I tried to listen to radio HEART on-line last night and it didn't work, it has done so before, there was no Internet sound slider in...
Flash no longer works
It seems my Flash no longer works. When I go to a site that uses Flash, there is a blank screen where the Flash player is located. I am using IE8 (32 bit). When I go to download Flash from the Adobe site, I get an error that there was a GUI error. Any ideas what is happening? BTW, I assumed...
Browsers & Mail
Xp Internet no longer works under win 7
Ok I just made the switch from xp to win 7 ultimate (64) and everything is working great exept the Internet, inside my computer I have a dlink DGE-530t I installed the driver on the cd, I also have a cable modem from videotron plugged in a dlink wireless router (with good win7 64 bit driver! ...
Network & Sharing
Backup no longer works
Haven't run a backup with Backup and Restore for a while as I've been using Geniesoft Timeline, but I like to keep 2 backups and run B&R occasionally to an external drive M:. Today, I have the problem shown in screenshot attached. Not sure what it means. The external drive is accessible as I can...
Backup and Restore
Mute no longer Works
Well I had an issue with my volume randomly turning itself down it seems to have solved itself I dunno how but i am not questioning it... now my mute on my quick launch buttons no longer functions would this be an indication of a driver issue with the quick launch or the sound device driver??
