Windows 7: Sound Recorder will not open.
30 Nov 2013   #1
DickH
Windows 7 64 bit
I have 2 e-machines, both bought about 2 years ago.
I have been using Sound Recorder in my machine (let's call it PC-1).
I can't find it in my wife's machine (let's call that PC-2).
When I look in WINDOWS/SYSTEM32 it is there, but when I double click on it I get the following:
01 Dec 2013   #2
fireberd
Windows 7/10 64 bit
It could be that feature is turned off, for whatever reason. Go to the Control Panel/Programs and then click on "Turn windows features on or off" and see if it is disabled in there.
01 Dec 2013   #3
DickH
Windows 7 64 bit
Thanks for the idea, but there is no "Sound Recorder" in the features section. Also. all the "Media" items are ON.
01 Dec 2013   #4
fireberd
Windows 7/10 64 bit
Check the Control Panel/Hardware and Sound and finally the Sound Panel, Recording section. There should be a default recording device set. Usually it is the Stereo Mix and then any device such as microphone or line in will be recorded. If it is not shown, RIGHT click in an blank area in that panel then click to show disabled and disconnected devices. If the Stereo Mix shows up, enable it and then set it as default recording device.
As a side note to your problem, if you want to record audio from the internet, you need the Stereo Mix to be able to do that.
01 Dec 2013   #5
DickH
Windows 7 64 bit
The Stereo Mix was disabled so I fixed that, but there is no Sound Recorder in the system. Searched all program files, etc.
FOUND IT, made a shortcut on the desktop. Now working OK. Thanks so much for your help.
01 Dec 2013   #6
fireberd
Windows 7/10 64 bit
Copy it over and see what happens.
I'm confused by the two screenshots you have. The second one with "An audio recording device could not be found" message would lead one to assume that there was no recording device (e.g. Stereo Mix), not that the program was corrupt.
01 Dec 2013   #7
DickH
Windows 7 64 bit
I was confused, too. Once I enabled the Stereo Mix, it works OK now.
01 Dec 2013   #8
fireberd
Windows 7/10 64 bit
OK, so my assumption that there wasn't any recording device and enabling the Stereo Mix, as I suggested fixed it.
Great. Glad I could help.
Sound Recorder - Open and Use
How to Open and Use Windows 7 Sound Recorder Sound Recorder lets you record a sound and save it as an audio file on your computer. This will show you how to open and use Sound Recorder in Windows 7.You can record sound from different audio devices, such as a microphone that's plugged into the...
Tutorials
Sound Recorder
Our messaging platform only supports wav files, which makes Sound Recorder in XP an excellent recording tool. For our customers using Vista machines, we instruct them to download a copy of Audicity, which allows them save a record message is a wav format. My questions is... Will W7 Sound...
Sound Recorder: I can't hear the sound
Several months ago I used Sound Recorder to record some songs using a USB microphone. I wrote in a file name and then played the songs back on Windows Media Player. When I recorded some songs this morning I went through the same steps but even though I saw the file in the WMP window, I could hear...
looking for best open source desktop recorder!
hey all, I'm looking to start a how-to/tutorial Channel on you tube and I need an application that will let me record my desktop for the duration of my demonstrations. if anyone knows anything please let me know, and thank you so much!
Software
Sound recorder
I've searched sound recorder, there isn't anything... its just gone? any idea?
Sound Recorder
I'm using Windows 7 Pro's (32-bit version) Sound Recorder to record vocals through a good mic (SM58 Shure) and Mackie mixer from the mixer's main (mono) output into the mic input on my HP dv7 laptop. It works wonderfully with little or no background noise and good signal level (sound level is set...
