Windows 7: Suggestions for cubase 7 professional sound card for Asus z87pro mobo
01 Dec 2013   #1
bethy1234
windows 7
Hi Chaps
I am looking for any suggestions for a professional soundcard for my new motherboard which is an asus z87pro. I was up until recently using an m-audio 1010lt audiocard with multiple ins and outs which i used with cubase 7. Since this card no longer fits i am looking for any alternatives which offer as much flexibility. All suggestions welcome.
01 Dec 2013   #2
cryptoncore
Windows 7 Ultimate x64, Windows 8.1 Pro x64 (on laptop)
what kind of price range?
This is 90 but it seems highly rated by producers online http://www.amazon.co.uk/ASUS-Xonar-D.../dp/B0011BC1FO
01 Dec 2013   #3
fireberd
I have a recording studio (I have Sonar X3 and ProTools MP9). Most do not recommend PC sound cards for recording. You are better off with a USB connected recording interface device. There are several in the under $200 US category including Focusrite (a UK company). The Focusrite Scarlett 2i2 is a popular two channel unit, that will accommodate either instrument or microphones and provide outputs for speakers or headphones.
Home | Focusrite
04 Dec 2013   #4
bethy1234
windows 7
Quote   Quote: Originally Posted by cryptoncore View Post
This is 90 but it seems highly rated by producers online ASUS Xonar D2X/XDT - Sound card - 118 dB SNR - 7.1 - PCI Express x1 [PC]: Amazon.co.uk: Computers & Accessories
Hi there I'm looking to spend around 200 for something with a similar number of ins and outs and midi/sp/dif connectivity, as i have a growing collection of synths and guitars. I've been looking at the M-Audio Avid Fast Track Ultra which could fit the bill costing 200+ duties.
04 Dec 2013   #5
fireberd
As I mentioned a USB connected device. One of my audio interface units is an MAudio Fastrack Ultra 8R (8 analog inputs).
I also have a Roland Octa-Capture (8 channels) which is my primary recording interface unit. They make smaller 2 and 4 channel units. I like the Octa-Capture as it has built in limiters that you can use (optional) when recording.
05 Dec 2013   #6
bethy1234
windows 7
Hi Fireberd,
Indeed, it is the MAudio Fastrack Ultra 8R version that I am quite keen on. yesterday i spent a few hours researching the user reviews. On the whole they seem very positive and i am inclined to wait for a used one to appear on Ebay. I also like the idea that it will just slot into my rack to save studio space. Can i ask if you have encountered any issues with yours?
AS for the Roland Octa-Capture, I shall check out what other users say their experience is.
05 Dec 2013   #7
fireberd
My Fastrack Ultra 8R is my backup unit. It rarely gets used. The Roland Octa-Capture is my primary recording unit.
The guru of music electronics, Craig Anderton has a review of the Octa-Capture on the harmony central site.
Roland Octa-Capture Interface - Now with Conclusio... - Harmony Central
15 Dec 2013   #8
bethy1234
windows 7
I've settled on theMAudio Fastrack Ultra 8R in the end, it should arrive from Ebay(USA) in about two weeks.
Thanks for your recommendation. One final question: have you encountered any issues with yours during your time with it?
best
Which usb 3 pci express cards for Asus z87pro mobo?
Hi team, I am considering adding a pair of pci express usb 3 cards to my mobo to run my ever-growing number of usb2 devices.. I have seen these 7 port cards on Ebay, ORICO PVU3-5O2I 7 Ports USB 3.0 20-Pin PCI-E express card Controller Hub New | eBay Has anybody used these? I would also...
Hardware & Devices
BitFenix Spectre 120mm Case Fan and Asus z87pro pin issue
Hi Team, I was recommended to buy some BitFenix Spectre 120mm Case Fans for my Asus z87pro board. The trouble is that the fans only have 3 pins and the mobo has multiple fan inputs setup to accept four pins. My specific questions are: will i damage my mobo if I try to use these fans, and...
Hardware & Devices
Just looking for some sound card advice and suggestions
Hi, I just got a new computer, Intel I7 2600 processor, 8 gb ram, nvidea 550TI, MSIp67a-c43 motherboard and have 3 pcix1 express slots and 3 regular pci slots available. There are no PCI expressx16 slots available. Windows 7 home premium. I currently have an integrated sound on the motherboard,...
old asus mobo can't detect sound with windows seven
this is my scenario... i installed a fresh windows 7. i'm using an onboard audio. my motherboard is P5ND2-SLI. obviously the sound wont work (i got the red X at the volume icon) without the latest windows 7 driver. after i installed the latest driver (6.0.1.6305), the red X is no more (the...
ASUS Mobo - No sound
I have spent about a week reading through the fixes offered in these great forums but have been unable to fix my system. I have a ASUS P5E WS Pro mobo. I have tried removing my sound card, reinstalling drivers, reinstalling sound card, reinstalling drivers and all combos of the above and yet I...
ASUS M2n e SLI mobo No sound but see line moving
I have the above mobo, just installed windows 7 64bit. Everything else is fine but I cannot get the sound to work even though wehen I test or play music I see the bar rise and fall. I have exhausted everything I know to do. I did see the CM6501 thread here but after trying the drivers, it still...
