Windows 7: Sound Randomly stops
01 Sep 2015   #11
ICIT2LOL
Quote   Quote: Originally Posted by venkateshr View Post
Quote   Quote: Originally Posted by stilli1988 View Post
so it seems it was my hdd. which is only a few weeks old hopefully it was some type of glitch or corrupted files or something from doing a large amount of copying to it. I wiped the drive and copied everything back from my backup drive and haven't had a problem yet. thx for your help guys.
Hi bud, I am experiencing the same issue here. Sound stops randomly in xonar stx. It only works after a restart. Was our issue fixed or did it come back? I was using Win 7, wiped that out and installed Win 8.1, still have the same issues. Installed uni xonar drivers, no change. I do not see how wiping the HDD completely fixed the issue. Did that really fix it? Should I try that too?
Hello venkateshr mate it is better you post your own thread - I know it is very tempting to ask when you see a very similar problem but having two individuals posting their issues in the same thread leads to confusion and inevitably distracting those of us who are attempting to answer the query.
Now again if you are running 8 then you should be posting in that forum - it is the same crew as here in 7 and is specific to 8 problems. You just need to sign up just as you did for this forum
Sound on Laptop and Desktop Randomly Stops Working and Working
So recently the sound on my desktop and my laptop has stopped working. For seemingly no reason. I really don't understand it. I first noticed it with my desktop. The sound just randomly stopped working. But not...entirely. It's really strange and complicated what's been happening, so bare with...
Sound stops working randomly after a while
Hi I've bought a set of new speakers for listening to music on my PC. However they stop playing randomly after a while. If I then go to the Device-manager and rightclick on the speakers (which is set as the default Device for sound) and do the test it works again for a while, whereupon the pattern...
Hi, My acer (aspier v5 171 Series) (windows 8) has been working smoothly for 1 year now, but since couple of days the sound would go off if something is not being played for sometime. then I need to restart to get it back...initially I though it happens after I lock the laptop but today it went...
Keyboard randomly stops working
So i have windows ultimate 32 bit, and i noticed this problem. My keyboard randomly, doesnt matter what im doing, stops working. All i hear is a beep and then the keyboard is frozen. Sometimes i can go into on-screen keyboard and press a few buttons and my keyboard will unfreeze, but sometimes i...
Hardware & Devices
Internet stops working randomly
Hi, I have a fresh install of Windows 7 on a (partly) new Desktop. Sometimes suddenly internet gets really slow and stops working. All other devices in my house (ipad, labtop (XP), phones) have no problems at all. This should suggest it's a problem of my PC but: Connecting to the WiFi of my...
Network & Sharing
Print job stops randomly
I nned some help to resolve the following trouble: Randomly on Windows 7 64 bits users can't print anymore whatever the printer choosen. Printers are shared on a network server . The only way close and log session again. regards
BSOD Help and Support
