Windows 7: Sound Randomly stops
08 Dec 2013   #1
stilli1988
Windows 7 Premium x64
Hi people. Having an annoying issue that's started occurring the last couple days.
As the title says my sound is dropping out at random times.
I've noticed it has occurred when my computer stops performing a task with sound.
It has stopped after playing a game, watching a movie and listening to youtube.
Once it stops it will not work again until I restart the computer.
Fixes I have tried so far include:
A- re-installing sound drivers
B- trying to restart the windows audio service but it gets stuck on restarting
C- reinstall my graphics driver to reinstall amd HDMI audio drivers
Recent changes I have made to my computer include some cable management, and the installation of a new HDD.
Once the sound stops, I cannot start up a game; a can play movies in vlc player with no sound but have to kill the process in the task manager; itunes will not play a song. The audio was working with the new HDD.
I have attached two dxdiag files one before the sound drops out and one after.
Thank you all for your help, Steven
09 Dec 2013   #2
stilli1988
anyone?
09 Dec 2013   #3
ICIT2LOL
Hello stilli mate where did you get the drivers from?? if you just used the Windows feature then you need to go to the Giga site and get them from there. http://www.gigabyte.com/products/product-page.aspx?pid=3438#dl
Before that run these
http://www.sevenforums.com/tutorials/433-disk-check.html < DO NOT run on a SSD
10 Dec 2013   #4
stilli1988
hi thanks for your reply. I did a clean install of windows and it still happened so i've formatted the hdd which i run most of my stuff from. i'll do the scan and install the driver and let you know how i go. cheers, Steven
10 Dec 2013   #5
ICIT2LOL
Hmm Steven mate it could be the board too mate if the Realtek driver from Giga doesn't work I might be inclined to stick a sound card in. I use the Asus Xonar DG that will drive up to a 7:1 system and I run a 5:1 Logitec Z506 off mine and the sound quality is superb and I am a bit of an audiophile.
The GUI for the card is great for mixing and effects and best part is it is cheap - $29 out here and worth every cent. Plus it cuts out the need for the onboard sound!
Sound Cards and Digital-to-Analog Converters - Xonar DG
10 Dec 2013   #6
stilli1988
i'm using a razor megalodon which i believe uses it's own drivers. but it happens with my regular speakers as well. I do however have a new board which i will attempt to install when i get my cpu and ram. i'll see how it goes. I formatted my hdd today so i'll find out if it's that.
10 Dec 2013   #7
ICIT2LOL
Yes Steven it (Razer) may use its drivers but the sound source (Realtek) will have its own hence why it is affecting both.
So why I suggested the Asus because it will cut out the on board sound source
14 Dec 2013   #8
stilli1988
so it seems it was my hdd. which is only a few weeks old hopefully it was some type of glitch or corrupted files or something from doing a large amount of copying to it. I wiped the drive and copied everything back from my backup drive and haven't had a problem yet. thx for your help guys.
14 Dec 2013   #9
ICIT2LOL
No probs just post back if it starts up again.
01 Sep 2015   #10
venkateshr
Windows 8.1 64 bit
Quote   Quote: Originally Posted by stilli1988 View Post
Hi bud, I am experiencing the same issue here. Sound stops randomly in xonar stx. It only works after a restart. Was our issue fixed or did it come back? I was using Win 7, wiped that out and installed Win 8.1, still have the same issues. Installed uni xonar drivers, no change. I do not see how wiping the HDD completely fixed the issue. Did that really fix it? Should I try that too?
Sound on Laptop and Desktop Randomly Stops Working and Working
So recently the sound on my desktop and my laptop has stopped working. For seemingly no reason. I really don't understand it. I first noticed it with my desktop. The sound just randomly stopped working. But not...entirely. It's really strange and complicated what's been happening, so bare with...
Sound stops working randomly after a while
Hi I've bought a set of new speakers for listening to music on my PC. However they stop playing randomly after a while. If I then go to the Device-manager and rightclick on the speakers (which is set as the default Device for sound) and do the test it works again for a while, whereupon the pattern...
Hi, My acer (aspier v5 171 Series) (windows 8) has been working smoothly for 1 year now, but since couple of days the sound would go off if something is not being played for sometime. then I need to restart to get it back...initially I though it happens after I lock the laptop but today it went...
Keyboard randomly stops working
So i have windows ultimate 32 bit, and i noticed this problem. My keyboard randomly, doesnt matter what im doing, stops working. All i hear is a beep and then the keyboard is frozen. Sometimes i can go into on-screen keyboard and press a few buttons and my keyboard will unfreeze, but sometimes i...
Hardware & Devices
Internet stops working randomly
Hi, I have a fresh install of Windows 7 on a (partly) new Desktop. Sometimes suddenly internet gets really slow and stops working. All other devices in my house (ipad, labtop (XP), phones) have no problems at all. This should suggest it's a problem of my PC but: Connecting to the WiFi of my...
Network & Sharing
Print job stops randomly
I nned some help to resolve the following trouble: Randomly on Windows 7 64 bits users can't print anymore whatever the printer choosen. Printers are shared on a network server . The only way close and log session again. regards
BSOD Help and Support
