microphone port problem
  1. Posts : 120
    Windows 7 64bit
    Howdy
    Both myself and my friend share a PC problem in common . We both own modern gaming pc's and we both have microphone and headphone ports up front/top of case
    The problem is the microphone ports don't work so we cant use headphone/mikes for Skype or online games. I have tried to configure mine without success.
    Thanks help appreciated.
  2. Posts : 21,004
    Scooby two things are you using a two plug headphone set and where exactly are the front panel audio leads plugged into? (In other words did you build these machines yourselves?)
  3. Posts : 4,161
    Windows 7 Pro-x64
    Also, do the rear ports work?
