Windows 7: Sound through jack output works randomly
15 Dec 2013   #1
VictorBF
Hi all,
Most of the time, I can't get any sound in my headphones. Sometimes it works, though, depending on Windows's launch. I mean, if it works, it will work flawlessly as long as I don't restart my laptop.
Config:
Toshiba C660-2D6
NVIDIA HD Audio
I have the latest version of the Realtek driver installed, yet Realtek Manager doesn't detect my headphones plugged in. They actually don't even show up in the sound devices window, even when sound works through them. I have screen captures available of what the software says with headphones jacked in, but I can't get them show up here. The "Insert image" thing doesn't seem to work. Here are the URLs anyway:
Realtek | Flickr - Photo Sharing!
Gest_son | Flickr - Photo Sharing!
I only have this problem with Windows. I have Ubuntu installed in dual boot and sound works perfectly, both in speakers and headphones. So, I know it is not a hardware problem. My wife has an ASUS with Realtek and NVIDIA installed as well but with old drivers, and she doesn't have any problem.
Any help appreciated!
16 Dec 2013   #2
rvcjew
7 Pro x64, 10 Pro x64
is this the driver your using? Détail des drivers - Toshiba also man was that hard to find even with google translate lol.
EDIT: also you can attach pictures with the paperclip to your post
16 Dec 2013   #3
VictorBF
Oh, sorry about that! I'm French, that's why!
Nope, I'm using this one : Realtek HD Audio Driver R2.73 Now Available
I tried and installed the one you mentioned, it didn't work. Besides, it is outdated. I also tried the previous version - R2.72 - of the one I've just posted in the link above. Didn't work either. I'm kind of stuck with this crap here and it is pretty annoying since I want to work on music writing, among other things.
16 Dec 2013   #4
rvcjew
You might need to use a tool like driver sweeper to get rid of all Realtek components and then reboot before installing those drivers that you linked will do anything.
16 Dec 2013   #5
VictorBF
Ok, I'll try that.
16 Dec 2013   #6
rvcjew
use this Guru3D - Driver Sweeper but make sure you only sweep realtek stuff. and uninstall your drivers first then reboot then run that then reboot and install new ones.
16 Dec 2013   #7
VictorBF
Roger that!
20 Dec 2013   #8
VictorBF
So, Driver Sweeper doesn't exist anymore. It has been replaced by a Display Driver Uninstaller, but it wasn't really the point since my display is ok so far
I've found another driver uninstaller, Driver Cleaner Pro. I ran it after uninstalling all Realtek-related things, and now I'm re-installing the latest audio driver. I'll see how it goes.
Also, I have experienced the same problem in Ubuntu one or twice lately, so I suspect the Realtek sound chip on my motherboard may be the trouble maker. What I don't understand is why I almost never have sound in my headphones on Windows, whereas I have it 99% of the time on Ubuntu. My laptop's a weirdo.
20 Dec 2013   #9
rvcjew
The os's are diffrent frameworks and as such Ubuntu is probably is using the alsa driver and Windows is using Realtek and alsa is more universal.
Sound works through HDMI output but not internal speakers.
I've just received my Laptop back from repair and all seems to be well, I had my screen panel replaced, gpu replaced(from 570m to 670m), new hard drive and CPU fan. However the problem I seem to be having is that internal speakers are completely not working. I can see that bolume bar in for my...
How do i output sound through the back panel jack and the front jack
Hey guys! I want to output sound both through the headphone jack on the front of my case and the sound jack at the back of the computer, how would i do this? I looked around in the sound setttings and the realtek audo and couldn't find anything.
HDMI Sound Works but Audio Jack Doesn't
I built a barebone kit and installed Windows 7 Ultimate 64bit, I installed all the drivers correctly but for some reason Windows keeps detecting the front audio jack as if someone is repeatedly pushing in and out headphones(no pun intended). Audio doesn't work at all through front and back audio...
HDMI sound output works just fine, audio jacks not at all! New PC
Hello everyone, you guys seem to know your stuff so Ill ask for your help: I have a frustrating problem with my brand new XPC Shuttle computer. Everything works fine, just not sound. I tried hooking up the computer via HDMI to a TV for the first time as I didnt have a monitor - sound works just...
No sound - Windows only showing front jack and not rear jack
Hi everyone, I recently reinstalled Windows 7 pro on my PC. Sound was working fine before. Now Windows only shows a front jack in the sound playback device settings. There is no front jack, however, only a rear jack and it is not working. If I play music the levels monitor shows sound playing,...
Can I Directly output audio from USB to 3.5mm jack?(My jack is broken)
Well my jack is broken since a few months so no joy for me... I hate it now when I can't listen to my music on my 14 speakers in my room. (NO KIDDING LOL) And today I was thinking about... HDMI... Audio?! Yes, but - I don't want to cut my only one hdmi cable which my parents use. So, I thought...
