Windows 7: microphone port problem
20 Dec 2013   #1
scoobydog
Windows 7 64bit
Howdy
Both myself and my friend share a PC problem in common . We both own modern gaming pc's and we both have microphone and headphone ports up front/top of case
The problem is the microphone ports don't work so we cant use headphone/mikes for Skype or online games. I have tried to configure mine without success.
Thanks help appreciated.
20 Dec 2013   #2
ICIT2LOL
Scooby two things are you using a two plug headphone set and where exactly are the front panel audio leads plugged into? (In other words did you build these machines yourselves?)
20 Dec 2013   #3
carwiz
Windows 7 Pro-x64
Also, do the rear ports work?
Can I use microphone port on MB to feed output to amplifier?
A very strange question. This is on my home theater setup. I have a smart TV. I want all my TV audio run through external speakers. The TV audio output is fixed level. It does not vary volume with the remote. Normally you would hook this up to an amplifier. What I want to do is send the fixed...
How can I change line in port to microphone
hello guys I have one problem when I put the microphone cable in pc he read like a line in no like a microphone and line in I can't use like a microphone did you know how to change line in in the microphone or can I change the line in jack information to microphone jack info.. ...
Problem with microphone when plugged to PC front port, Win 7 & Realtek
If i connect my headset with microphone to port in my PC's front, it notifys both new microphone (line out) and headphones (line in) (no usb, dont remeber what its called in english, ports also working cause notifys new devices). I have Windows 7 installed and Realtek HD Audio Manager and its...
I have problem with my microphone .
I cant get my microphone work . I have Creative Sound Blaster X-Fi Titanium PCI Express Sound Card i have tried going to creative console launcher and check the microphone box.
Microphone problem
Used to use my Dell Inspiron 1525 without any issue when it came to skype. However I recently upgraded to Windows 7 and now I'm having issues with the microfone. It's just not working properly :( It works for sometime and then you can't hear anything anymore (for the person your chatting...
Problem with my microphone
Hi everyone, I worked for a long time with Windows XP. I used this computer for podcast recording: - Windows XP - Input: Stereo-Mix Now, I have a new computer, Windows 7 Ultimate 32bit. When I plug my microphone in my computer and start Audacity, the sound is very bad. It's the same...
