Realtek HD Audio Manager not there/problem with headset
  1. Posts : 1
    Windows 7 Ultimate x32
    Hi everybody, since this is the first time using sevenforums I will try to make it readable.
    So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do nothing ( that includes front and back green jack's ), I thought Realtek HD AudioManager will show me but that ain't in the Control Panel under Large Icons or similar. I really don't know what to do with my headset now, might the problem be in the jack?
    Sorry for bad explaining and english, But I sincerly hope you know what I mean.
    Regards, Fenix1214 :)
    Do you have a separate sound card? along with the RealTek on the motherboard audio? Or just the RealTek audio?
    The RealTek audio manager, in my PC, is located in the Control Panel/Hardware and Sound.
    As the front panel headset is not recognized, the first step is to check the connection from the front panel to the motherboard, if you have RealTek on the motherboard audio. Make sure the connector is fully and properly seated.
    If you have a separate sound card, the front panel headphone/mic jack must be connected to the separate sound card.
