Windows 7: Realtek HD Audio Manager not there/problem with headset
22 Dec 2013   #1
Fenix1214
Windows 7 Ultimate x32
Hi everybody, since this is the first time using sevenforums I will try to make it readable.
So I got sound card with 5.1 speakers on it, and headset sound will work if I put in jack into there where my speakers are, but If I put headset jack elsewhere it won't recognize the device and will do nothing ( that includes front and back green jack's ), I thought Realtek HD AudioManager will show me but that ain't in the Control Panel under Large Icons or similar. I really don't know what to do with my headset now, might the problem be in the jack?
Sorry for bad explaining and english, But I sincerly hope you know what I mean.
Regards, Fenix1214
22 Dec 2013   #2
fireberd
Do you have a separate sound card? along with the RealTek on the motherboard audio? Or just the RealTek audio?
The RealTek audio manager, in my PC, is located in the Control Panel/Hardware and Sound.
As the front panel headset is not recognized, the first step is to check the connection from the front panel to the motherboard, if you have RealTek on the motherboard audio. Make sure the connector is fully and properly seated.
If you have a separate sound card, the front panel headphone/mic jack must be connected to the separate sound card.
Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore...
New Realtek HD Audio Manager Driver Problem with Microphone
Hello, I'm CrazyKilla So I recently got a new motherboard and because it's a new board, it came with it's own audio drivers, and my old ones were useless (obviously). I installed these new audio drivers and i found that it changed the look (and most likely the software itself) of the Realtek HD...
Realtek Audio HD Manager Equilizer Problem
When one of my friends built this computer for me, the Realtek Audio Manager was working flawlessly. It's been about a year since this computer was first built, and now I'm having troubles with the program. Usually I was able to adjust the sounds using the equalizer and the Room correction, now I...
Problem with realtek hd audio manager
Hello,everyone i have a problem with realtek hd audio manager.I installed the latest drivers and i dont have the audio manager i am working with Windows 7 Ultimate 64bit as the same i was working on my PC before,but now i am with laptop Acer TravelMate 5760G and i dont have the realtek manager,can...
Realtek HD Audio Manager Problem!
So, I have Realtek HD Audio Manager installed, and the latest drivers. My sound is now working fine, but my microphone isn't even being picked up. I don't know what kind of problem this is, but I was looking for help. My motherboard with on-board sound is a ECS Elitegroup GeForce7050m-m. Thanks for...
Realtek HD Audio Manager and Realtek Audio Driver
Help. I recently did a clean install of Windows 7 64bit (on my HP Vista 32 machine). Life is grand! My problems started when I tried to listen to the microphone input through my speakers. The front microphone inputs did not work so I downlaed the Realtek HD Audio Drivers (recently updated) from...
