Realtek mic problems :(
  1. Posts : 4
    Sometimes my mic dose not get recognised, but sometimes it dose. If it finally dose get recognised a few mins later it will say "you have unplugged something from your audio jack" when i didn't even touch anything.. So then i open up realtek and see that the mic is still connected, but sometimes it says there is no mic connected after that notification pops up.
    I know my mic is the problems because when i unplugged my mic and not the head set audio jack the problem stopped. BUT, i switched out my head set and the problem is still there so i know i dont have a broken headset.
    I reinstalled audio drivers and chipset drivers with no luck
    i cleaned my connectors and dusted my computer
    Made sure all connectors were connected
    tryed connecting to the back and still the problems there
    plz help THANKS!!
  2. Posts : 4,161
    Windows 7 Pro-x64
    Did you reboot and see if the problem goes away?
    Go to the Realtek HD Audio Manager from the Control Panel then click on the Advanced settings in the upper right corner. Chose separate input. Then check to see if the problem follows when moving to the back mic jack.
    Attached Thumbnails Attached Thumbnails Realtek mic problems :(-realtek-separate-input.jpg
  3. Posts : 4
    Well to be honest the issue stopped at arround 12 am last night with the head set pluged into the back jacks as well as the mic. so maby front audio panel problem?
    if it starts going crazy again i will do as you told me to. Also, you have a older driver version. the new one looks so cool man!
  4. Posts : 4
    well the message poped up again, im going to do what you told me to do, crossing my fingers it wont happen again! thanks for the help so far!
  5. Posts : 4,161
    Windows 7 Pro-x64
    I'm older too. :) If it ain't broke, don't fix it.
    Are you sure you have the correct driver for your motherboard? Where did you get the "new" driver?
  6. Posts : 4
