Windows 7: Intermittent popping/crackling noise during audio playback
24 Dec 2013   #1
tks95747
Windows 7 Home Premium 64 bit
Hi Everyone:
I have a Sony Vaio VPCL23CFX All-in-one desktop computer (See my SPECS).
I have an odd problem that I cannot seem to resolve. When I play a song, any song, or any MUSIC, for that matter, I get a popping/crackling noise every once in a while. Sometimes it won't happen for a minute, then it will happen every 5 or 10 seconds and then it will stop, then it will start back up again with the every 10 seconds and then not for a minute thing.
It NEVER happens when no music is playing, for example, during a movie when there is no soundtrack playing or if I am watching a Youtube video that has no music. I get the same popping/crackling noise whether it is though the computer speakers or through the headphones.
Does anyone have any idea what might be causing this to happen or how I might get it to stop?
Thanks,
T
25 Dec 2013   #2
fireberd
Windows 7/10 64 bit
Popping and crackling, if you look over the old posts here, is a frequent issue. Unfortunately there is no "one fix" for the problem.
Among many potential issues, sound drivers (make sure you have the correct sound driver from Sony), video drivers, Wi-Fi, power supply, external source such as a wireless phone or cell phone close by.
On the audio, if you only have the generic Windows installed "HD Audio Codec" that is the first place to start. Get the correct sound driver. What you list for the Sound Card is not really what it is, correct designation is "RealTek", according to the Sony site.
25 Dec 2013   #3
tks95747
Thanks for the info. I finally figured out what was causing the problem. It was my Atheros Wireless Network Adapter. Once I disabled it, no more popping/crackling.
T
25 Dec 2013   #4
fireberd
Windows 7/10 64 bit
The Wi-Fi as I mentioned was one potential cause.
26 Jan 2014   #5
nfusion48
windows 7
Quote   Quote: Originally Posted by tks95747 View Post
T
hi - was just starting to also troubleshoot this issue over here and this was my first thread in my google search...so, i disabled it at my end and it wouldnt connect via wifi afterwards.....i just started using a router for the first time and never had this issue with connection via a wireless modem...
so, i disabled the generic ethernet controller instead and while i still can connect to the net i still have same noise (audio crackling) issue...am i missing something? i am trying to update drivers to adapter - Atheros AR500EG - but searching forever online with no return software to update..any other ideas would be greatly appreciated
i am running Vista though...shouldnt make any diff , right?
i will try to figure out in interim and check back - thanks in advance for any reply
Audio Popping/Crackling
I just bought windows 7 for the first time and after installation and installing all drivers I realized I only had one issue. For some reason when audio starts or ends there is popping/crackling noise. Does anyone know how to fix this? I'm using a Sennheiser PC 350 headset and on board audio...
Crackling and popping audio.
Hi all; Question about the audio on my laptop. Have any of you ever experienced "popping" during audio playback? It says the drivers are working ok. It never threw a code or anything. Any suggestions, ideas as to goings on?
6 months now and still no solution to audio Crackling/Popping/Dropouts
Im desperate here as I simply cannot figure out the solution is and this thing is driving me nuts. I have major latency issues and from DPC checker have figured out that its my network adapters (or at least I think). When I disable both of them, I get nearly perfect sound. Ive re installed...
Seemingly random audio crackling/popping
Lately I've been having a problem where my audio snaps and pops. It's not constant but it can get pretty noticeable. Especially on more calm music. It occurs while any audio is playing. Skype calls, Youtube videos, songs, video games. Anything. At first I had thought it was simply because my...
Audio Popping/Crackling/Static Windows 7 x64 on Asus f50 Series
Hello 7 forums, I'm having an issue with my audio that is driving me up a wall. I'm having that (apparently common) issue of crackling/popping/static-y audio on a Realtek chip. I've tried multiple drivers, from Realtek official to Generic to Vista ones. My latency graph has little to no spiking...
Audio Crackling noise
thanks for taking the time to read this and help me with my problem ok the problem is i started to install Crysis Warhead and i started playing it and there was no audio so i unplugged my headphones and plugged em back in nothing still so i saved my game and quit then all i was hearing was...
